EM TuningChris Nott
Results 1 to 7 of 7
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Lowering an S-Line & fitting 19s
    OK, so I'm thinking of lowering my S-Line (2007 model, sportback TDI 170 quattro) and have some questions:-
    * Are Eibachs the best choice of springs?
    * Which part nos fits the S-line?
    * How much will they lower the car?
    * Are there any issues with the ABS/quattro when lowering?
    I'm also considering swapping the 18s for 19s:-
    * What offset are the Audi 18s?
    * What width/offset are required when fitting 19s?
    * What size tyres are recommended?
    * Do they rub with std suspension and will they rub when lowered?
    Boydie
    19"x8.5" et50 offset
    235/35/19 tyres
    my 2.0tdi sport (non quattro) has FK coilovers installed, and its only lowered 25mm all round
    i have no problems at all with rubbing even with full load
    only on full lock left do i get a little bit of rubbing on the inner arch but nothing to write home about in my opinion!
    if you buy springs eg 30mm, it will actually only lower the car 15mm or there abouts
    i would go for 50mm springs or get your self a set of adjustable shocks and springs or a coilover kit
    i have no problems with ABS and you won't have any.
    dont know about the quattro but i doubt it would be an issue
    hope this helps
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    I would add that when I got my 2005 S-Line it had the Eibach Sportsline springs fitted with stock shocks and it would rub with passengers in the back and ocasionally on fast dips in the road.
    I still have the Sportsline springs if you anyone is after a set they are for a 2005 3 door s-line 2.0TDI DSG (may fit others).
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Thanks guys.
    How much did the Eibachs lower your 2005 S-Line?
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Quote Originally Posted by maars
    Thanks guys.
    Ignore that - just got a reply from Eibach and they've told me their Pro-Kit lowers a std A3 30mm, and thus an S-Line only 5mm. Bummer.
    Any other recommended spring kits?
    maars's Avatar
    Full speed ahead
    May 2007
    567
    Apparantly H&R do a kit - 35mm lowering for a std car, so 10mm lower on a S-Line. Does anyone have an H&R kit fitted?
    Rabbit222's Avatar
    Jul 2007
    South Africa
    666
    Hi, I'm new to the forum. I have fitted H&Rs to my 07 S3 and it touches a bit on the rear. Looks like it may be the two screws attached to the fenderliner Will check it out later today and hopefully post up some decent pics
