AH FabricationsEM Tuning
    stevehsv868's Avatar
    Unofficial Audi UK Endurance Test Driver
    Feb 2007
    Stoke-on-Trent
    100
    Genuine Audi Parts WHERE FROM ?????
    Does anyone have any links, for cheap genuine Audi parts ????????
    im looking to convert my 288mm TDI brakes to either
    312mm which is just carriers and discs, (simple cheap DIY option)
    345mm S3 Front set up, which is carriers calipers disca and pads.
    and help greatly appreciated
    LAND ROVER DEFENDER 2.5 Td5
    EGR valve removed, DE-cat down pipe, Turbo boost pressure increased to 22 psi, Upgraded full size intercooler, Stage 3 remap, single mass flywheel conversion, with performance pressure plate and racing friction disc. 210hp 500 Nm
    The Audi A3 2.0 TDI S line DSG Has gone and forgotten
    d3fy's Avatar
    Sep 2005
    Sheffield
    1,411
    http://www.audi-accessories.co.uk/
    Or VAG Parts or your local stealer.
    2.0T Quattro SLine, now 320d Sport Touring
    Beddie's Avatar
    Dec 2006
    239
    Hiya mate,
    Here's a couple of part numbers which may be useful to you, obviously you would be best to double check with the dealer before ordering etc etc..
    288 x 25mm Disc Setup
    Disc: 1K0 615 301T
    Carriers: 1K0 615 125 or /.......125-D
    Calipers: 1K0 615 123 or / ......124
    312 x 25mm Disc Setup
    Disc: 1K0 615 301AA -
    Carriers: 1K0 615 125-C
    Calipers: Not required if upgrading from 288mm
    345 x 30mm Disc Setup
    Disc: 1K0 615 301M
    Carriers: 1K0 615 125-B
    Calipers: 1K0 615 123-C or / ......124-C
