Volks AutosChris Nott
    Jul 2006
    36
    Question Mcgard locking wheel bolts
    I've recently fitted some new RS4 alloys to my A3 and am in need of some locking bolts.
    I've found some 30mm shank length tapered ones on eBay (27181) but the rest of my bolts measure 28.5mm (27222) - wondered if the 30mm ones will fit?
    Mcgard product specs: http://mcgard-europe.de/englisch/subolzen.htm
    Apr 2007
    144
    right, easy way to find out.
    Take off wheel and put existing bolt through hole in wheel so you see how much thread is sticking out. Mark or measure this protruding length
    Then mark another 2 mm on the bolt and put the bolt into the hub and wind in to the 2nd mark, this will equate to a longer bolt. Check the hub rotates without interference
    If it does then you should be fine
    2007 A6 Allroad 3.2 FSI Quattro - Lava Grey, sports seats, silver Headlining, Acoustic parking, armrest, multi-function steering wheel, cruise control, Xenons, , Sat nav, GSM, Audi MMI
    Jul 2006
    36
    Good thinking, ta.
    d3fy's Avatar
    Sep 2005
    Sheffield
    1,411
    http://www.autoexpress.co.uk/product...eel_bolts.html
    Have a read before you splash the cash the Ultra are the ones to go for
    2.0T Quattro SLine, now 320d Sport Touring
