Monster MotorsportChris Nott
Results 1 to 11 of 11
    dkelly's Avatar
    Sep 2006
    Bicester
    48
    Emission Control System light's on.
    As the title suggests the light has just come on. Does anyone have any answers.
    I have an (04) 2.0 tdi sport which has 62k on it and this light has just come on. There's no power loss, fuel consumption is the same, the engine runs fine, apart from the light you'd never know.
    I'll get it checked out Monday, but do ya think its OK to drive?
    DK
    stevehsv868's Avatar
    Unofficial Audi UK Endurance Test Driver
    Feb 2007
    Stoke-on-Trent
    100
    my emission control light came on after i disconnected the vacum pipe to the EGR valve (exhaust gas recirculation valve) have a look round there , its monunted on the intake manifold.
    and the emision control light came on my mums 2.0 TDI that was the intake flat motor, which is mounted below the EGR valve.
    LAND ROVER DEFENDER 2.5 Td5
    EGR valve removed, DE-cat down pipe, Turbo boost pressure increased to 22 psi, Upgraded full size intercooler, Stage 3 remap, single mass flywheel conversion, with performance pressure plate and racing friction disc. 210hp 500 Nm
    The Audi A3 2.0 TDI S line DSG Has gone and forgotten
    dkelly's Avatar
    Sep 2006
    Bicester
    48
    I will check this thanks.
    I thought i read that somewhere else. i think you did it to stop the hesitation, and it did but left the light on. I still have my hesitation.
    I'll take it to APS tomorrow, as they a very local, and get it diagnosed.
    I have searched in here and it has happened to others and the cause seems to be a relay for the glow plugs.
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    If it is the intake flap motor - it will usually also take out one of the fuses in the Engine fuse box and from memory this is also used by the fan controller.
    There is an Audi TSB on the subject of the Intake Flap I had one changed under warranty a few months ago.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    DSGSport's Avatar
    Mar 2005
    Hertfordshire
    22
    Intake flap
    I had the same problem on mine a few weeks ago, 54 plate 2.0tdi. I had the Flap Motor replaced under Warranty.
    A3(8P) 2.0 TDI Sport, DSG ,Akoya Silver, Bose Upgrade, 18" RS6 Replicas, GMBH Vortex Kit, Red Leather, Rain and Light sensor pack, rear mats, K&N pannel filter...and now Milltek Cat back system with Straight through Mid Pipe
    Nov 2004
    South East
    317
    Check your oil cap under the bonnet. My emission light came on, although all seemed ok with the car. Audi roadside technician found that the oil cap was slightly undone, although I had not touched it since day one of ownership. The technician found a small piece of plastic had broken off it and replaced the cap for me. Fine since. However, it took him longer to re-configure the engine software and do all his checks on his laptop than it took him to drive to an Audi dealership and back with the new cap! Superb service though in my opinion.
    2006MY A3 Sportback, 3.2 SLine, Manual, Brilliant Red
    dkelly's Avatar
    Sep 2006
    Bicester
    48
    Thanks for your help guy's. It was the EGR.
    APS diagnosed it and it'll be replaced on Thursday. Out of warranty unfortunately. but there you go.
    Once again thanks. DK
    dkelly's Avatar
    Sep 2006
    Bicester
    48
    It was the throttle body that had jamed and caused the fuse to melt affecting a fan and the aircon.
    Al sorted now.
    Feb 2007
    Hampshire
    1,654
    There was an Audi TSB on that so you should really have had that done FOC by Audi.
    VCDS HEX-USB+CAN
    dkelly's Avatar
    Sep 2006
    Bicester
    48
    Hi Gti Jazz Blue
    I called Audi and my dealer and they said no as it was out of warranty so NO! They were quite straight about it.
    The car is 3 months and 2k miles out.
    Thanks for your help though.
    DK
    Feb 2007
    Hampshire
    1,654
    I guess then it would have had to be Sale of Goods Act as it is a known faulty component.
    VCDS HEX-USB+CAN
