AH FabricationsChris Nott
Results 1 to 8 of 8
    Aug 2006
    Chester
    6
    2.0TDI Hesitation / Service Fix
    My A3 2 litre TDI goes in for it's first service next week. It has a hesitation at 2400rpm on a changing throttle, it's not there when you drive through that engine speed on a constant throttle.
    It seems to have got worse recently, does anyone know what causes it and can it be sorted at the service ... or is it a case of they all do it?
    thanks
    Andy
    p.s. I did search first but couldn't find anything.
    Mar 2007
    10
    Do you mean if you come off the throttle and then back on you get a slight jerk/hesitation because mine does the same thing and also when feathering the throttle on flat roads to maintain speed sometimes.
    My car went in for a flash update but it still does it from time to time. My car has only covered a few thousand miles so is'nt ready for a service for quite some time.
    Tell us what they say after the delaer has evaluated this problem. Sorry I can't help anymore than that.
    dkelly's Avatar
    Sep 2006
    Bicester
    48
    Mine too.
    I've got a 04 with 60k+ on it and it has had the same thing from the day i got it (18mths & 43k ago). I have had a re-flash and a new MAF and no change. They say there is nothing more they can do and I can't get them to recreate it everytime so the stealer can't be arsed.
    I have learnt to live with it but if you can find out i'd love to know.
    DK
    Aug 2006
    Chester
    6
    Well it came back from the service yesterday exactly the same in terms of the hesitation. In fact, the dealer didn't even call me to let me know if they looked at the problem, I'm going to call them tomrrow.
    However, since the service my DIS is indicating that the fuel economy seems to have dropped 7~10mpg on my normal journeys.
    Completely bizarre.
    Andy
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    I had the same hesitation on my 1.9TDi, and it turned out being the EGR valve. I'm not sure what it does, something to do with the exhaust gases being recirculated through the turbo.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    Jul 2007
    Co. Durham
    I have had this problem, my first A3 54 plate 2.0Tdi Sport Sportback , it was back to the dealership several times and at one point they had it for 4 weeks! Surprise Surprise they could not get it to repeat the fault.
    After spending far to much time at the dealership not getting any further forward and only owning the car for 6 months we decided to complain in writing, after a lot of tooing and froing they agreed to buy the car back, not at the price we had paid though, however they offered us any other second-hand car at cost plus 50. I ended up with a better car a 55 plate 2.0 Tdi S-Line Quattro 3dr for a small extra cost.
    However this one is now doing the same fault, not as bad though. I haven't had this one back in yet, no point I think and have now resigned myself to the fact that this must be a quirk of the engine?
    stevehsv868's Avatar
    Unofficial Audi UK Endurance Test Driver
    Feb 2007
    Stoke-on-Trent
    100
    hello
    I have a 2006 2.0 TDI S line DSG covered 25,000 miles and it has the same fault.
    the problem must be caused by the EGR valve (Exhaust gas Recirculation valve) this valve lets a proportion of the exhaust gases back into the inlet manifold for the engine to burn again, its a way of keeping the particulates down and the NoX.
    I have disconnected the vacume pipe that operates the valve. but the engine management light comes on. so it had to be reconnected. But whilst disconnected it did stop the fault. I have also tried blocking off the pipe that carries the exhaust gaes, but the engine management light still comes on.
    I have heard that you can change the ammount of times the EGR valve opens with VAG COM. But I am not sure on this.
    Does anyone have VAG COM experience ???????????
    LAND ROVER DEFENDER 2.5 Td5
    EGR valve removed, DE-cat down pipe, Turbo boost pressure increased to 22 psi, Upgraded full size intercooler, Stage 3 remap, single mass flywheel conversion, with performance pressure plate and racing friction disc. 210hp 500 Nm
    The Audi A3 2.0 TDI S line DSG Has gone and forgotten
    Nov 2007
    South Devon
    179
    Have had similar (slight) hesitation with a VW Touran 2 TDi: workshop manager thought perhaps one of the 'PDs' but unable to find fault through diagnostics (he agreed the hesitation was there after driving the car). Co-incidentally while looking for another fault at the same time (intermittent cut out of ventilation they eventually got notice from VW that an airflow temperature sensor is a known prob. After two months (!) replacement part arrived, fitted, hesitation appears to have gone and mpg improved about 10%.... Odd. Now awaiting a Sportback 2 TDi for January delivery, can't wait!!
