Monster MotorsportBadger5
Results 1 to 9 of 9
Thread: Carpet
    rxs1407's Avatar
    Mar 2007
    Hampshire, UK
    106
    Carpet
    When getting the tyre swapped this morning, i pulled the drivers side carpet mat out to get some dirt of it.
    Then i noticed the stud that holds the carpet in place wasn't there... it was stuck to the underside of the mat.
    So i'm guessing the other part is under the carpet?? Does anyone know the quickest way to get the carpet up , so i can grab the bit the connect them up again??
    Thanks Dodge
    A4 Avant S-Line 2.0TDI Leather Trim,Phone Prep, Heated & Electric Front Seats, Audi Parking Plus, Cruise Control, B&O Sound System, Autogym, Boot Liner.......
    JohnS3's Avatar
    Oct 2004
    3,021
    I think you might have to take the door sill trim off so you can get your hand underneath the carpet.
    Regards, John.
    rxs1407's Avatar
    Mar 2007
    Hampshire, UK
    106
    Quote Originally Posted by JohnS3
    Regards, John.
    Are they easy to remove???
    sjahS3's Avatar
    Apr 2007
    London
    167
    Dodge - same thing happened on mine and ended up taking it into the dealers. Apparently driver's seat needs to come out to pull up carpet and replace studs !
    All under warranty and took 2 hours or so.. but a royal pain in the ar$e.
    HTH.
    -Sal-
    S3 - Phantom Black with a few options..
    rxs1407's Avatar
    Mar 2007
    Hampshire, UK
    106
    Quote Originally Posted by sjahS3
    HTH.
    -Sal-
    Cheers for the reply, all done i removed all screws i could find and the ones holding the front of the seats down.
    Then i managed to get my hand under the carpet (nightmare as the carpet has the sound proofing fix to it) and found the clip, put it back in hole, clipped on the top piece and a drop of superglue to hold it..
    Put the screws back in and all finished.
    cheers for the help
    Dodge
    sjahS3's Avatar
    Apr 2007
    London
    167
    Nice one .. seems to happen quite a lot.
    I'll try that next time one of mine goes again..
    -Sal-
    Trev241's Avatar
    Mar 2007
    229
    Had this happen twice on A3 Quattro some years ago, since then I have always taken the precaution of using something to push down on the centre stud whilst pulling up the carpet.
    Just takes the pressure off the fixing, never fancied the thought of the stealer ripping the seats out.
    Trev
    rxs1407's Avatar
    Mar 2007
    Hampshire, UK
    106
    Quote Originally Posted by TrevS3
    Most other makes seem to have screw in ones, save pulling the carpet up!!!
    sjahS3's Avatar
    Apr 2007
    London
    167
    Thumbs up
    Reluctantly gave my car into FR Audi (for the first time.. esp after reading some reviews) to get this sorted but fair play to them, did a decent job and valeted the car inside, out so couldn't complain !
    -Sal-
