Badger5Chris Nott
    Jun 2007
    Audi A3 1.8S (2000) Cambelt
    Hi
    Apologies up front I'm new to the forum ;-) Just had a nice man from the AA tell me my Cambelt has snapped. Luckily I was in a traffic jam and doing only 5-10mph and pulled over.
    I would like a little advice from you experts out there if poss?
    The car is an Audi A3 1.8S (2000) and is in reasonable condition, is it worth looking at repairing it or should I cut my losses and sell it on as a spares/repair job for someone obviously more qualified than I?? I know it probably depends on bent rods, piston heads and stuff just wondered best and worst case scenarios? Any advice would be much appreciated.
    Regards
    Nige1
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Hello and welcome.
    Nige, may be worth posting this in the A3 8L platform for your model, this side is for the newer shape A3.
    May get a better response there.
    Good luck,
    TDI/
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    Worse case you will have the following
    Bent Valves
    Damaged Pistons
    Damaged Head
    Possibly damaged water pump pulley and oil pump pulley but very small chances.
    Jun 2007
    Thanks for the replies guys ;-)
    N
    Apr 2004
    1,139
    not sure about this, certain engines get damaged more from this than others - road speed is irrelvant as even at tickover those engine parts are moving towards each other at a great rate of knotts with nowhere to go!
    Jun 2007
    Thanks Steve ;-)
