Volks AutosJMB Retrofits
    May 2007
    13
    A3 2.3 Sportline Quattro DSG
    can anyone tell me if you can fit a turbo to an A3 3.2 and who carries out the modification.
    Regards
    Peter Hopper
    Boydie
    do a google search for VW R32 turbo's - they are the same engine and there have been plenty of conversions done in the past
    edit: on a very quick search i found
    http://www.eiptuning.com/eip/r32_turbo_systems_01.html
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    Would a DSG box cope with the extra power & torque?
    May 2007
    13
    Boydie thanks for the links and Matt will need to check this out when I get the low down on the turbo, first thoughts are yes it will cope as it has obviously been beefed up for this engine in the first place.
    Thanks guy's
    Boydie
    more than likely you will have to import a turbo kit but as i said, do some research for any british tuning companies
    im sure it cant be that hard, just expensive!
    Jan 2005
    108
    i looked at it in the past and you do have to be careful with the dsg box as i'm pretty sure on all current re-maps they have to limit the torque
