Chris NottMonster Motorsport
Results 1 to 20 of 20
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Post Type pressure monitor
    Anyone got this option, i know it's only Ł45, and was wondering if there are complications with sensors in the tyres etc.
    Thanks,
    TDI/
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    I have this option on my Sportback.
    There are no sensors or anything in the tyres. The system works using the ABS sensors to compare the speed and therefore the rolling cicumference of the wheels. If the rolling circumference of one of the wheels changes, then the warning system is activated.
    Dave R (h5djr)
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Cheers Dave.
    Oct 2006
    246
    Quote Originally Posted by h5djr
    Do you know what pressure drop is needed to make the system activate. Just wondering if its sensitive enough to detetc a 3-4 psi drop or whether it needs a big drop to make it work.
    Just curious.
    No, the is no indication in the Owner's Manual. Perhaps I will have to try it, gradually letting air out of one of the tyres and taking the car down the road to see at what point it gives a warning.
    Dave R (h5djr)
    Sportback owner
    Apr 2007
    France
    465
    Tyre pressure sensor
    Interesting post. Does anyone know if this facility can be retrofitted to a 2006 A3 2.0L TDI vehicle? Price? It looks to be mostly software, since there are no tyre sensors to fit. Thanks in advance.
    jamiekip
    I'd be interested in considering a retro fit if it was cheap enough.
    What would be required????
    Apr 2007
    41
    It can be retro fitted see: http://oooo-a3.blogspot.com/2006/04/...stem-tpms.html
    Not done it myself but am certainly interested in doing so
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    Apr 2004
    1,139
    its not very good to be honest - mum has it on her SEAT altea (exact same system) and it doesn't detect a pressure change of about 5psi. The systems which have sensors in the wheels are far more accurate. Personally if its free great but not worth paying ANY amount of money for - by the time it registers pressure loss it would be enough to visually see that the tyre has lost pressure.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Would be interesting for h5djr to try this on his car and see how accurate it is!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Yeah, come on Dave
    Jun 2007
    Ballater, UK
    7
    I have it fitted to my A3 and Im not very impresed with it. On one occasion I noticed the car was pulling due to slightly flat tyre but the indicator never warned me about it.. On another occasion I had my tyres at 42psi, due to heavy load, but when I took them back to there usual pressure it never picked it up either. Maybe faulty on mine wont be the 1st thing!!!!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Quote Originally Posted by Diadem
    Well it wouldn't unless they were different pressures surely?
    8P2 S3
    sjahS3's Avatar
    Apr 2007
    London
    167
    Would possibly be interested in a retro-fit.. but again only if it is worth the extra $$$ and integrates as the OEM would.
    -Sal-
    S3 - Phantom Black with a few options..
    Aug 2005
    West London
    850
    Mine worked really well after I adjusted the pressure when the car was new. I only changed the front wheels by +2psi each and the warning came on about 1-1.5miles away.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    murray
    Nov 2006
    Surrey
    17
    I have it and it works well.
    Came on a couple of weeks ago and one tyre was down about 2psi.
    Jun 2007
    Ballater, UK
    7
    Quote Originally Posted by staz1000
    When you change the pressures on the tyres you are have to reset the system to tell the car you did it.
    I never reset it to see if it worked but it didnt.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Well I ordered the parts so will be attempting this retro-fit next week.
    Pars for this are really cheap so got to be worth a go.
    I 'll let you know how I get on.
    Sep 2006
    Surrey
    1,224
    Quote Originally Posted by marms
    Goodluck mate. Take plenty of pics!
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
