Monster MotorsportChris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 112 of 112
  1. #81
    They look much better than the normal 'yellow' bulbs. What type did you get in the end?
    Dave R (h5djr)
  3. #82
    jonnyc's Avatar
    Jul 2007
    846
    Just ordered a set of PIAA sidelights and DRL bulbs.. Both are 4150k colour so should match xenons pretty well..
    Ill post some pics when i have them both done.. Plus some new rims!!
    MK5 ED30.. Fastest MK5 / 2.0T FSI in the UK - Fastest DSG MK5 in the world!
    12.601 @ 115.85 MPH
  4. #83
    thebears's Avatar
    Oct 2003
    85
    Quote Originally Posted by JamS3
    Take it the ordinary DRL bulb is on the left and the new one on the right?
    If so do you have a link for the replacement ones you have that get rid of the yellow look please as I wouldn't mind some.
    Yes the replacement is on the right. I ordered these!
    http://www.priracing.com/product.php...4789a2d048f33d
    A3 2.0 TDI Sport - Currently Broken
  5. #84
    Not anymore - Back 2 BMW (shh)
    Aug 2006
    Norwich, Norfolk
    357
    Does it make any difference that they are rated at 27W?
  6. #85
    Aug 2007
    41
    Quote Originally Posted by h5djr
    No, DRLs are not side or parking lights as they are better described. DRLs are, at the moment, only on A3s fitted with Bi-Xenon headlights.
    Dave, my A3 is MY2008 and it has a switch to put on the DRLs. I don't have Xenons. I must check to see if they work!
    Like yourself, I have an SE, do the auto headlights switch of the DRLs when they come on by the sensor?
    Do you always use your DRLs?
    Paul
    ______________________________
    A3 2.0 TFSI Sportback SE S-tronic Ice Silver
  7. #86
    Hi Paul. Yes I use my DRLs all the time. I'm surprised that you have a switch for DRLs on your A3 because it's where the levelling switch used to be to adjust the normal halogen headlights if you have a heavy load in the back. This is not necessary with Xenons as they are required by law to have automatic levelling.
    The DRLs do automaticlly switch off whenever the main headlights come on either by me or the automatic light sensors switching them on.
    Dave R (h5djr)
  8. #87
    Sep 2006
    Surrey
    1,224
    And if you don't have DRL's, what kind of bulb do you require to change them?
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
  9. #88
    Change what?
    Dave R (h5djr)
  10. #89
    Sep 2006
    Surrey
    1,224
    The yellowish bulb that I have. I've got Xenons but not Bi-Xenons, just need to know the kind of bulb I need to get to match it with my Xenons. Sorry for being a little slow on the intake, just getting confused with all the differents types of bulbs...
  11. #90
    Aug 2007
    41
    So you should be Dave because on consulting the manual and checking again I now realise that I don't have the switch. It just confirms that you should never rely on a salesman doing the handover. The switch indicated by him was the arriving home lights switch!
    BTW Dave do you have 16 or 17 inch wheels on your SE, how would you describe the ride and road noise?
    Paul
  12. #91
    I had 16 inch wheels on my previous A3 2.0TDI-140 SE and I have 17 inch wheels on my current A3 Sportback. Personally I don't notice much, if any, difference in the ride quality between them. As far as road noise is concerned I think the road surface makes more difference than anything else. Appearance wise I much prefer my current 17 inch, 16-spoke design.
    HERE is a link to a phote of my current Sportback
    Near where I live they have recently completed a new bypass which joins on to the end of an existing road of similar type. Both are dual carriageways. The old road is quite noisey, but the new section is surfaced with the lastest 'quite' type of tarmac that also allows the water to drain through. When you go from the old section to the new section everything suddenly goes very quiet. Also when it's raining there is a lot of spray from the old section which disappears completly in the new section.
    Dave R (h5djr)
  13. #92
    Aug 2007
    41
    My A3 is almost identical to yours except I have the roof rails.
    Previously, I had an A4 Avant and its suspension was quite hard. I blamed the Sport suspension and the 17" wheels. So when I went for a new Audi, I went for a petrol A3 SE because it would be lighter and I expected the suspension would be softer. My teenagers felt that they had more space in the rear than in the A4.
    The A3 Sport I had on test drive was softer than the A4. However, the SE suspension with the 17" wheels on my A3 is not much softer and the tyres pick up a lot of road noise on "certain" surfaces as you have found. New road surfaces are very quiet. My tyres have very high pressure and this could be a factor in the hard ride. I have Primacy Pilot tyres.
    Paul
  14. #93
    thebears's Avatar
    Oct 2003
    85
    Quote Originally Posted by MJZ 6370
  15. #94
    The tyres on my A3 are the same, Michelin Pilot Primacys X2E - 225/45R17-91W. I current have them set at the pressures listed inside the fuel flap - 35 front and 32 rear.
    Dave R (h5djr)
  16. #95
    thebears's Avatar
    Oct 2003
    85
  17. #96
    si_reading's Avatar
    May 2007
    Cheshire, UK
    168
    I got the same above PIAA DRL's the other week and also got some PIAA sidelight bulbs. Fitted DRL's no problem but I can't get the sidelight bulbs out at all!! Do they twist out or pull? It's such a tight fit it's very hard to get your hand in the back of the unit.
    Si
    2009-Current | Porsche Boxster 2.7
    2007-2009 | Audi A3 2.0 TDI 170 S-Line
    2005-2007 | Audi A3 1.6FSI Sport
  18. #97
    You had better start a new thread if your going to ask anything about the sidelight bulbs otherwise 'thebears' will get annoyed and post a 'OFF TOPIC' sign!
    But seriously, they do just pull out. I have never tried but, by all accounts, they are very difficult to get out.
    Dave R (h5djr)
  19. #98
    thebears's Avatar
    Oct 2003
    85
    At least bulbs are related to the topic. My SE tyres aren't though are they?
  20. #99
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Quote Originally Posted by Dandle
    Mine are always on. I coded the back lights so they come on with DRLs as well(also have the lights on the bootlid lit as tail lights).
    I know you can set the rear lights to come on with the DRL's - but how do you get the inners to come on as tail lights? Are the bulbs and bulbholders in there already twin filament? So the brighter, 21W filament is the foglight and the 5W is the tail light?
    Can this be set using VAG.com?
    Spence
    ________________________________________
    Now: 2011 A4 Avant 2.0TDi Black Edition Multitronic Aruba Blue
    Gone at 77k: 2008 A4 Saloon 2.0TDi 140 S-Line Quartz Grey
    Gone at 80k: 2007 A3 Sportback 2.0T S-Line S-Tronic Mauritius Blue
    (4 S-Tronic boxes, 3 Mechatronics Units, 2 Dual Mass flywheels, 2 sets of engine mounts)
    Gone at 32k: 2005 A3 Sportback 2.0TDi 140 S-Line DSG
    Ebony Black
  21. #100
    Only answering MJZ 6370's questions - perhaps I should have been rude and say it's nothing to do with this thread!
    Dave R (h5djr)
  22. #101
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    So then....
    The best DRL replacement bulbs that match the Xenons and dont melt any casings and throw warning lights on the dash are.......
    Link please!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
  23. #102
    Aug 2006
    Norwich, Norfolk
    357
    And... does it matter that they are rated at 27W and not 21W?
  24. #103
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,721
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
  25. #104
    thebears's Avatar
    Oct 2003
    85
    Quote Originally Posted by mitch78
    These are the best in my opinion, and as you can see, I've tried everything.
    And no, the 27W rating doesn't matter, they are labelled as being suitable replacements for 21W bulbs.
    I confir and i actually think they are slightly dimmer than the 21w of previous, probably due to the blue coating. I've been running mine all day when i drive, no excess heat, no melting and a great "white" light.
    with having the sprint blue, the blue of the bulb blends in and more or less looks like a reflection.
  26. #105
    thebears's Avatar
    Oct 2003
    85
    You could also use PM to communicate about specifics! Was'nt suggesting to be rude, just keep threads on topic!
  27. #106
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    So they don't melt anything on the car then?
  28. #107
    mitch78's Avatar
    Mar 2007
    2,721
    Ex 8L S3 driver
  29. #108
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Still haven't seen a sidelight bulb I like?!
  30. #109
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Quote Originally Posted by AL_B
    I'm thinking of these...
    Not sure if the DRL's are 382 or 380 fitment...
    PIAA Xtreme White 4150K
    My enquiry with Priracing has not yet been answered
    AL
    Guys,
    Just for your info, I've been running these for a month or two now. I have taken pics, but need to post up.
    All I can say is I am very happy with the light given off by them, much whiter than the standard bulbs. The only drawback, if you can call it that, is when the bulbs are not on they are blue. Giving the car a "blue eyes" look.
    I also bought the PIAA Xtreme White side-light bulbs which are a pretty good match to the Xenons. Would prefer LEDS, but can't be arse messing around putting in resistor packs etc.
    So no bulb warnings for me.
    AL
    '07 Phantom Black S3 - '07 to now - Bucket Seats, FBMFSW, BOSE, Symphony II+, Cruise Control, Elec Folding Mirrors, Front Centre Armrest, Rear Armrest & Through Load, Interior Light Pack, Luggage Pack, Reversible Boot Mat, Luggage net.
    '02 Silver S3 (225bhp) - '02 to '07
    '99 A3 1.8T - '99 to '02
    '11 Rising Blue Golf R - '12 to now - 19" Black Talladega's
    '52 Black Golf GTi MkIV Anniversary - '03 to '12
  31. #110
    S3 LTN
    AL
    ive ordered the DRLs but cant manage to find the Xtreme sidelight blubs on the website.
    Would u mind sending me a link for the sidelight bulbs.
    So eager to get rid of them yellow lights.
  32. #111
    AL_B's Avatar
    1,564
    Quote Originally Posted by S3 LTN
    AL
    Hi mate,
    Sorry for the late reply.
    Here is the link...
    http://www.priracing.com/product.php?xProd=120&xSec=29
    AL
  33. #112
    S3 LTN
    cheers AL
    nice one
