Chris NottVolks Autos
Results 1 to 20 of 20
    A5GUR's Avatar
    May 2007
    Solihull, West Midlands
    54
    NAVI MEMORY CARDS
    Not sure if this is in the correct area. Im looking at getting a 4gb memory card for my 2007 S3 which will be arriving in the very near future. What is the best card to go for:
    - MMC
    - SD
    Im a little confused. The brochure says it takes both. So dont want to order the wrong. What is the best make? cheers
    Jan 2007
    Hampshire
    1,155
    SD is the way to go, but bear in mind the file limit of 512 per card. Unless your tunes are encoded at a high bitrate then the file limit will be reached before the card is full.
    I use Sandisk cards but dont think is much between the different brands to be honest, bought mine from www.mobymemory.com
    A6 3.0 TDI.
    Not anymore - Back 2 BMW (shh)
    Aug 2006
    Norwich, Norfolk
    357
    Didn't think you can have a card that exceeds 256MB in the RNS-E? I've tried 2GB (with up-to-date firmware) no joy!
    Aug 2005
    West London
    850
    I use 1 Adata 4gb SD card 150x and a 2gb Adata 150x. Both work perfectly and i have non of the problems some people find with a slow initial load. Takes about 15-20seconds the first time the 4gb one is inserted. Got them both from here http://www.emartbuy.co.uk/products.php?prodid=99. Be carefull buying SD cards though from ebay as many of them are bad copies and wont work properly or will be very slow.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
    A5GUR's Avatar
    May 2007
    54
    thats a shame. i wasnt aware there was a maximum capaciy limit. I just assumed you can put whichever size cards you wish in. So is 256 or 512 the max? Can still get approx 125 song on a 512. cheers
    Aug 2005
    West London
    850
    No, the limit to the amount of files you can put on there is 512 files(tracks and folders all included). As i said I have a 4gb card and it works fine in the RNS-E. I have about 3gb of music on it although some of them are 30-45 minute long tape rips. All tracks on mine are @192 bit rate.
    A5GUR's Avatar
    May 2007
    54
    Oh right. my bad. So i can still get a 4gb. But the max songs i can have (without folders etc) is 512. That site doesent have anything in stock! Thanks for the supeeerr qucik reply dandle.
    A5GUR's Avatar
    May 2007
    54
    Ed
    Ed's Avatar
    Oct 2006
    Farnham
    185
    The best SD card I have ever had is a SanDisk Extreme III, the speeds of transfer is unbelievable compared to standard SD cards.
    http://www.picstop.co.uk/ is a good place to get memory cards.
    Aug 2005
    West London
    850
    There are lots of fake card on ebay, they even come in what looks like original packaging but its not. I would only buy from Uk based webshops to be sure then you should get original cards although they wont be as cheap as ebay ones.
    Aug 2005
    West London
    850
    Quote Originally Posted by Ed
    They are only 133x cards the adata ones I use are 150x. Not that it would make much difference I guess.
    Vertigo1's Avatar
    Jul 2006
    2,487
    I'm using two 4GB own-brand cards from MobyMemory and they work perfectly. Unfortunately they don't seem to sell them anymore, only having the Transcend ones at 30 quid, whereas the ones I have were 20 quid!
    Aug 2005
    West London
    850
    Good site Vertigo not seen that before. They are really cheap.
    Vertigo1's Avatar
    Jul 2006
    2,487
    Yeah I get all my memory cards from them - they charge reasonably delivery too which helps when only spending 20-30 quid.
    murray
    Nov 2006
    Surrey
    17
    Just make sure when you buy your SD card that you don't buy the SD HC variety.....I can tell you they do not work. 4Gb works fine, I too have used the Moby Memory cards which are good value and work well (you don't need to buy the 150x version) with very little download time.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    I've got 2 Kingston 2GB cards in mine and they work fine, bought from www.mymemory.co.uk
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Sep 2006
    Surrey
    1,224
    What are the SD 150x called?
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    Aug 2005
    West London
    850
    They are just SD cards with a 150x read speed.
    Sep 2006
    Surrey
    1,224
    Doesn't it have a particular brand for it e.g. SD Extreme 4 or something? Just so I know that's all
    Aug 2005
    West London
    850
    No some brands have their own name for it others just quote the speed.
