funguf said:So in essence I'm restarting the counter for the annual service? Is anything else required apart from oil change? I bought the car from Audi with 7600 miles have now done 9600 miles and am planning to get them to change to interval.
JamS3 said:will it be reliable as fixed service cars?
Power also has nothing whatsoever to do with oil changes in its own right. A 100bhp 1.2 16v has the same configuration and number of moving parts as a 200bhp 2.0 16v turbo
2 year old oil, in a 2 litre turbo charged engine running over 200bhp isnt a great idea..... no matter what audi say
steve184 said:Power also has nothing whatsoever to do with oil changes in its own right. A 100bhp 1.2 16v has the same configuration and number of moving parts as a 200bhp 2.0 16v turbo
S3-ROB said:Can't agree with that, thats like saying a Renault clio can go 20000 miles between oil changes and a Bugatti Veyron will be fine aswell
Performance turbo engines run hotter internally, normally rev higher, the people who buy them drive them harder than a basic model so need extra maintenance
I would never use long life servicing personally, if you buy the car new and plan on selling it after 3 years then maybe but not for me
I change the oil every 6 months in my S3 and the oil is still clean and clear when drained
Not trying to cause an arguement here and i'm not saying i'm right, its just my opinion :icon_thumright:
Oil should be black.
That means it's doing it's job,suspending 'crap' in itself
S3-ROB said:Partly agree but because i do regular oil changes my engine doesn't get a build up of 'crap' and the oil stays cleaner for longer, the internal sludge that builds up without regular changes can at worst block oil ways and the oil pump pick-up pipe leading to oil starvation
That's taking things to extremes.
That ain't going to happen under AVS mileages using AVS oil,is it now
A fool and his money though
no not much money at all, but £15 a year MORE than what you need to spend - because it isn't going to make the slightest difference to your cars performance or longevity
In summary, if you change your oil more often then you will add life to your engine.
If 2 engines driven identically had their oil changed one at AVS and one at every 10k then the 10k would show less wear
S3-ROB said:Yes thats what i was trying to get at :icon_thumright:
Anyway i'm gonna leave it at that, i'm new to the site and don't want to make enemies or upset anyone, my comments are only personal opinion which we're all entitled to and we all treat our cars in different ways
A4Quattro said:If 2 engines driven identically had their oil changed one at AVS and one at every 10k then the 10k would show less wear.
A4Quattro said:In summary, if you change your oil more often then you will add life to your engine.
bowfer said:Baseless speculation.
A4Quattro said:Not baseless nor speculation.
Don't use big words just to try and illustrate a worthless point
