Sky InsuranceJMB Retrofits
    Detector's Avatar
    Just waiting for the green light
    May 2007
    Midlands
    130
    Symphony 3 with multifunction steering wheel
    If anyone has this exact specification could they check to see which functions do what the owners manual say, so far I can only find volume control is correct, please PM me if you would.
    Forget phone prep part !
    170 S.line manual
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by Detector
    the right wheel does volume up\down. the left wheel does track up\down or radio station up\down depending on whether you are using cd or radio.
    the other buttons do nothing unless you have the phone prep installed. if you do then the mode button changes from radio to cd to phone. the right button is for the voice menus.
    Detector's Avatar
    May 2007
    Midlands
    130
    OK then, then right roller is correct, the left however should change either CD tracks up for next track, down for last or in radio mode up for next programmed chanel 1-6 or down for last programmed channel.
    Is this the same in yours or is it reversed ?
    170 S.line manual
    jamiekip
    The left button will also let you fast forward/scan through a track - push and hold the roller button.
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by MarcQuinlivan
    The other buttons do nothing unless you have the phone prep installed. if you do then the mode button changes from radio to cd to phone. the right button is for the voice menus.
    Mmmmm, my mode button just goes from radio or CD back to phone prep again.
    Vertigo1's Avatar
    Jul 2006
    2,660
    yes that's right, Marc was getting a bit confused I think - it won't switch between CD and radio, just switched between the current audio source display on the DIS and the phonebook.
