I'm hoping for advice and to tap into the experience of others. I have a 3.2 quattro and having changed all the tyres recently (for the Goodyear F1s), I had the tracking checked and adjusted because both of the front tyres had worn on the inside edges.
I believe that the tracking was checked properly; 2 hours at a local Audi specialist with the recommended equipment, who reported on all angles including the thrust angle. However, in the 5k+ miles I've done since then I've found that all 4 tyres are now showing wear on their outside edges. The wear seems to be even across all of the tyres.
Has anyone else experienced this? Can someone explain a misalignment which would cause all 4 outside edges to wear more quickly, or is it something I just have to accept?
Thanks,
Thanks,
