AH FabricationsBadger5
    May 2007
    Servotronic Relay Location
    Have an 07 A3 2.0t and I want to pull out the servotronic relay as steering assist can't be adjusted with vag com on the 07. I have read that this has been done on other Audis with no issues. Problem is I can't find it. Any ideas?
    Thanks,
    Sean
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I think the ECU might detect a fault if the relay is missing and will come up with an error code.
