Chris NottAH Fabrications
Results 1 to 12 of 12
    Dec 2006
    Norwich
    437
    FUELING UP GROAN?
    Guy`s -done a search but on previous threads there did`nt seem to be an answer as such(maybe there is`nt one?) My 3.2 q is a right Cow to get filled up-it takes ages at the pump as I have to just trickle fuel in to stop it clicking off? Tried all sorts of methods of getting it in but it wont have it? This really does tick me off as being 3.2 its something I have to do once\twice a week Any tips anyone-love the motor other than this???
    A3 3.2 Q SPORT DSG Now...Edition 30 Golf GTI
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by Wes G
    I've had this problem with both my A3s when they were new. I actually said it to the dealer after I bought the first one, and he said it is something to do with the design of the neck, but that once you get used to it, it is easy. He also said that they had quite a few customers coming in with the same problem.
    When I got my new A3 in January I had the same problem, even though I had "gotten used to it" on the old one. I've found if you put the nozzle in with the handle at about 7-8 o'clock you should have no trouble with it. I do that and have had no trouble with the new car since.
    I must admit, I felt like a bit of a gimp the first couple of times at the pump. It used to take so long the pimple-faced teenager used to keep coming over asking if I was OK.
    Dec 2006
    Norwich
    437
    Will give that a try & see if helps???...Thanx
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Think yourself lucky,it's only a year or so ago that the fuel flaps were sticking shut,so you couldn't even get to fill up !
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Sep 2006
    Surrey
    1,224
    Yea I hate that! Only happened to me couple hours ago. Filling up £10 in my TDI at BP and everytime I pulled the handle it just kept flicking up and stopped pumping. Could only pull it abit so it went in veryyyy slowlyyyy.
    Happens all the time But i'll try the 7-8 o'clock angle
    Audi A3 (8P) 2.0TDI SE .:. Ebony Black, Sports Suspension, Vienna Beige Sports Leather Seats, Concert II & BOSE, 6 CD-Changer, Xenons, Acoustic Parking Sensors & All The Packs .:.
    Gone but not forgotten
    It can depend on the actual pump used. I've had the problem at a couple of filing stations but have no problem at all at either the two stations I normally use. If I do get a problem I've found that only putting the pump nozzle part way in the filler can help.
    Dave R (h5djr)
    Jan 2007
    10
    Had the same prob with my 3.2.
    To solve just put the nozzle 4/5th's of the way in. That'll sort it!
    Jonesy
    Mar 2007
    53
    yeh just turn it to 7/8 o clock works fine
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    I never have this problem, i only go to Shell for the Optimax though so i dunno if pumps vary between stations.
    Mar 2007
    78
    No probs with my 07 SB
    mcmasman's Avatar
    Mar 2007
    Norway
    152
    Most of my previous cars(Audi or not) has the same problem at the pump when I put the nozzle fully in. To me, it feels like that if the pump is quite strong the petrol will splash abit in the tank and in return making the nozzle think it's full. Although I don't know the exact science how the gas pump works and prevent overfill, that's the general feeling...
    When I pump petrol, I put the nozzle 80 % all the way in and tilt the nose up as much as i can. I can imagine in that case the nozzle is as far as from the splashing petrol and prevent it from stopping pre-meturely. That "might" increase the chance of overfilling, but I believe that if you know your car well, you should know how much your car can hold in the tank. And plus, you can hear from the pumping noise that it's getting full, then you just have to slow down to top it up.
    2007 Lava grey A3 2.0 140 TDI Quattro Sportsback
    S-line int/ext, cruise, mfsw, aluminum rails, Xenons+, coming-leaving home, light + rain, parking sensors, hill hold, Bluefin, 18" OEM double 7-spokes RS4 alloys
    Dec 2006
    Norwich
    437
    Cheers for the advise guys-However I have now tried everything thats been posted and still does it? Going to give a friend of mine a call @ Norwich Audi (Robinsons) see if he has any ideas? I might use a normal unleaded pump?(normally use v power) I cant see that this would make any difference but will give it a go? Other than that I`ll just put up with it taking a bit longer @ the pumps Thanx anyway
