EM TuningMonster Motorsport
Results 1 to 7 of 7
Thread: TV option
    Mar 2007
    52
    TV option
    Anyone know how easy it is to rewire the TV so that you can have it on whilst driving (for the sake of passengers obviously)....
    Dec 2006
    Ireland
    2,538
    With the VAG stuff you need to buy an adapter cable to enable it. It is called "Video In Motion".
    I've bought a couple of these from a company called NavTV in Cardiff.
    Check them out here
    I called them before Christmas for some information on the RNS-E and they told me they were only able to activate the CD based navigation units, but that they hoped to have a solution for the DVD based option soon.
    Mar 2007
    52
    Ok thx - will give them a buzz when I get the new S3
    Being a bit of a newbie and seeing those cables....once its done nothing is on view, right?
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    Check out http://www.navplus.us as well - it's been done on there too, but I can't recall whether it was with VAG-COM or a special CD software update. I know the latter is being worked on (a group of users are trying to decompile the RNS-E software).
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    Dec 2006
    Ireland
    2,538
    Quote Originally Posted by KARL
    nah, the cables sit in behind the head unit. you take the cable from the back of the head unit, put it into one end of the new cable, and put the other end of it into the head unit where the original cable was.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The best solution is the tool to enable VIM on the HU without additional wires or parts, It does not affect the Navigation as the hardwired solution does.
    The cost to do is £79 and I have the tool. You need your Nav system PIN code to use the tool as the Nav system is reporgrammed out of the car.
    Mar 2007
    52
    Quote Originally Posted by s8craig
    The cost to do is 79 and I have the tool. You need your Nav system PIN code to use the tool as the Nav system is reporgrammed out of the car.
    Can u elaborate on how the navigation is affected by the hard wired option?
