Sky InsuranceBadger5
    Boydie
    Flipping Rear Lights!
    If some may remember i had a problem with my left rear dirving light
    Members suggested using WD40, changing bulbs and scratching the connections
    did this and didnt work
    all of a sudden about a day later both lights are working - happy days!!
    then the right light goes!! i do the same as before but to no avail
    anyone experienced this?
    could it just be a loose wire??
    all help appreciated!
    thanks
    Dec 2006
    Ireland
    2,538
    yeah, I had something similar with my previous (04) A3. DIS warning light came on for tail light, then when I got to the garage to buy a replacement bulb it had gone out (the warning light, that is), so I didn't bother buying the bulb. It happenned another couple of times too.
    Never did work out the cause of it.
    Boydie
    lol same old story -the day i go to the dealers to sort it the DIS light will go out!
    ive done everything i can think off - must be a wiring problem!!
