Monster MotorsportChris Nott
Results 1 to 7 of 7
Thread: Noisy wipers
    Mar 2007
    Leicester
    Noisy wipers
    Is it just mine....
    Every now and then normally in intermittant mode the wipers appear to hit each other briefly at the bottom of the screen just before they start to come up again. Doesn't do it all the time. no set cycle to it either. Weirdly it almost never seems to do it when the wipers are on constant when its raining..
    Also there are no marks on the edges of the wipers to suggest they are hitting each other..
    Any ideas ???
    rich1068's Avatar
    Jun 2006
    Sheffield
    673
    I think there's some sort of recall on for wiper motors at the moment. Maybe something to do with that?
    A3 2.0T FSI Quattro S-Line
    Gone...and quite quickly forgotten
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    I would check that the wipers are tightly bolted down. I tried to use the wipers one frosty morning, and one moved but the other was still frozen to the glass, which put them out-of-sync. When I checked later, the bolts (underneath each small plastic cover) were really loose. Took minutes to adjust them and tighten both up again.
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    Mar 2007
    Newbury, UK
    82
    I noticed that my wipers seem to have two different park positions, one about 40mm higher than the other, being what I call normal position. Maybe something to do with that...
    Phantom Black Sportback 2.0 TDi 140 S-line.
    Options: Full Leather, Symphony, Bose and Bluetooth
    OEM-Mods:Ambient & Map Light
    MiT
    MiT's Avatar
    Work Hard, Play harder!!
    Mar 2007
    Birmingham
    269
    I think mine are similar to the first post.
    When in auto rain sensor mode, the left sits a little higher then the right. And then sometimes it move up slighty and down again. But when in normal constant sue, and you switch them off, its ok.
    wierd. So you think this is related to this wiper recall? How can i find out?
    A3 Sportback 2.0 TDI S-Line
    Amalfi White || Comfort Pack || Audi Sound System 10 Speakers || Interior Light Pack || Elec Lumber Support || Sat Nav || Non Smoking pack
    SamDude's Avatar
    Jan 2007
    London
    2,091
    The wipers 'park' at a slightly different location each time when in use. They will rest at the lowest position when switched off.
    This is a feature to avoid rubber fatigue if I'm not wrong...
    MiT
    MiT's Avatar
    Mar 2007
    Birmingham
    269
    Quote Originally Posted by SamDude
    nice one sam, so that means nothing is wrong then. How come only the left one does this?
