Results 1 to 11 of 11
Thread: RS4 Alloys
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    RS4 Alloys
    Have the chance of 4 genuine RS4 alloys and was wondering if they would fit my car without causing any handling/quattro problems?
    Asked the Audi dealer and they didn't really know, only said the standard S3 alloys are offset ET 54 and the RS4 ones are ET 29 which does not mean much to me!!
    They come with tyres 255/35/19, i didn't realise the tyres were so fat on a RS4.
    Have noticed though looking round Audi seem to have done the same for RS4 alloys what they did for the old 18in RSTT alloys in that the genuine ones off a TT or 8L S3 were dished in the middle and the spokes bent towards the dish. The replicas both from other companies and Audi themselves (if not bought on a genuine model) were flat faced.
    Saw some 18in RS4's on a new TT in the showroom yesterday and they were completely flat compared to the RS4 next to it!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    The lower the offset the further the wheels will stick out. For that reason I think you'd struggle to get them to fit onto an S3. Someone may correct me but I think thats the right way round...
    With a higher offset you can use spacers to get them to sit more flush with the arches.
    2004 1.9TDi A4 Avant Sport, GmbH bodykit, DPM Remap, Fishscale Alu trim, RNS-E
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    According to a book I have:
    "Offset - this is determined by the distance from the wheel mounting face in relation to it's centre line. The offset figure is denoted by ET, which stands for Einpress Tiefe in German, or Pressed-in depth. The lower the offset, the more the wheels will stick out."
    8P2 S3
    RAPS3's Avatar
    Moo Moo Land
    1,040
    So then the ET29 less ET54 is equivalent to a 25mm spacer. Which I think would be a little too much
    BUT you could always be different and have the wheel faces machined back to give you a narrower offset. (The machine shop near teeside Audi will be able to do them for you Jam ! )
    Paul R
    S3 Sportback - Sprint, Buckets, Bose, Rain & light, Alu rails, Piano trim, FT Warning, Bluetooth prep
    S3's now sold - roll on the Golf MK1 Project
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    If you machined the faces of the wheels that would need bigger spacers surely?
    8P2 S3
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    I dont think so, as you'd surely just machine off the correct amount to make them sit flush with the arches.
    I doubt I'd have them machined though just in case it affects the integrity of the wheels. But perhaps I'm just a softy walter..??
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    an offset of 29 will not fit without rubbing. Your looking at a max of 45 maybe 42mm.
    J.
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    What I mean is if the RS4 hubs stick out further, then the wheel face will be further towards the outside of the wheel so machining part of the face off would make the face even further away from where the S3 hub would sit.
    I know what I mean but it's a bit hard in text to explain.
    Basically if you need a spacer then taking some metal off the wheel would mean you need a bigger spacer.
    8P2 S3
    RAPS3's Avatar
    Moo Moo Land
    1,040
    Not necessarily, it depends on the construction of the wheel I suppose.
    It depends on whether the wheel centres are closer or further away from the outer edge of the rim. I know what you mean it just depends on how the wheels are constructed.
    Do the RS4's have a wider track due to the hubs being further out, longer shafts, wishbones etc or are the wheels just offset more and the actual track / distance between the two hubs set up the same width as the "normal" A4's
    Paul R
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    I'm guessing but I think the track must be slightly wider. The arches on the RS4 are flared and I think they are flared more than the 20mm or so difference in ET.
    willnabby's Avatar
    RS-one day soon!!
    Nov 2006
    sheffield
    593
    Iv'e fitted 17" RS4 replicas to my sportback the first set came with an ET35 offset and they protruded the arches by 10mm so i got them changed for ET45 offset and they now fit flush with the arch.
