Was under the black plastic trim where the windscreen wipers are on the 8L chassis, not checked where it is on my new one but probs will be in the same location?
its in the passenger footwell under the glove box ,there is a plastic screw you can turn , you pull the rubber foam down and it is behind a plastic cover you have to slide , cant remember if you slide it left or right.
my aircon smelt bad untill i hooverd the filter out and sprayed with fabreeze
