Badger5Chris Nott
Results 1 to 9 of 9
    mjepson's Avatar
    Dec 2006
    175
    Removing suspension help (pics)
    I was trying to remove the suspension at the front to fit new springs, but stumbled upon some problems.
    I got the lower bolt out without to much trouble, but the top bolt wont come loose cause i can't hold it on the other side. The rod (don't know what its called) is on the other side of this bolt. I have marked it on the third pic with a question mark.
    Does anybody know how to remove this bolt?
    Audi A3 8P 2.0 TDI S-Line Lava-grey // BBS CK 8x19 ET44 // 215/35 R19 Dunlop Sport FM901 // Eibach Sportline 50/40mm // Bluefin
    Click HERE to see the pages from the electronic workshop manual in connection with the front suspension struts.
    Hope this helps.
    Dave R (h5djr)
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    thats the anti-roll bar link, try hitting it with a hammer (as if you were fitting it as opposed to removing it) as the part with the thread on is tapered.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    mjepson's Avatar
    Dec 2006
    175
    Thanks for the elsa pdf...
    but this doesn't exactly tell me how to unscrew the bolt:
    Unscrew top hexagon nut for coupling
    rod -arrow- from suspension strut.
    I will try hitting it with a hammer although i don't understand what you mean about it being tapered
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    its a balljoint, it has a threaded portion and a tapered portion, see this picture...
    The tighter the nut is the more the shaft is pulled into its housing
    Chris
    See my images @
    Oct 2006
    83
    try clamping the joint tight with a pair of grips or something, i use some plumbers grips to hold the joint tight while i undo the nut
    Dec 2004
    Chester
    247
    I think you will find if you look at the head of the bolt where it comes through the nut there will be either a torx or allen head inside the protruding bolt, this is to stop it spinning while you undo the nut with a spanner
    TTS, 19's,DSG,Sat Nav,phone,elec seats,bose,ex leather,and more
    Dec 2006
    N.Ireland
    369
    use a spanner to undo the nut and use a TX bit to hold the drop link in place, this will stop the joint spinning
    mjepson's Avatar
    Dec 2006
    175
    I found this very nice instrution on the seat site... for anybody else on here who are going to change. Almost the same as A3.
    How to Replace Seat Ibiza Rear Shock Absorbers: Changing rear shock absorbers on a Seat Ibiza Mk4 is surprisingly easy for the home mechanic. This guide shows you how.
    How to Replace Seat Ibiza Front Shock Absorbers: Changing the front shock absorbers on a Seat Ibiza Mk4 is a different matter - possible for the home mechanic but only just. This guide shows you how I did it.
