Results 1 to 13 of 13
    A3simon's Avatar
    Nov 2006
    Aberdeen
    976
    Anyone bought a Forge FMIC
    http://www.dpmautostyling.co.uk/cata...oducts_id=3321
    Ive been looking at this for a while and after speaking to Damian aka DPM i reckon im going to order one when i order my wheels from him especially as he is a fair bit cheaper than Forge themselves. Just wondering if anyone else has bought one and if so what they make of it good fit, easy installation and any noted differences
    2009 Suzuki GSXR1000K9 SE in White
    2012 Triumph Speed Triple R in Black
    2012 RS3 in Racing Mica Blue
    2012 A1 TFSI in Misano red (shared with mum)
    Boydie
    i dont know about the a3 but my mate bought a forge FMIC for his mk3 ibiza cupra 1.8t
    it was an easy-ish fit and looked awesome through the grill and performed very well
    however the support brakets did snap!! but this was instantly replaced by forge with no hassle and i think posting costs were reinbursed
    wouldnt put me off forge - id consider buying off them if the made a upgraded FMIC for the 2.0tdi
    Learning to fly 3D
    Jan 2007
    Essex
    195
    Lowering the intake temps is a good thing, and will see a power gain, but to take advantage of this you are going to need the boost pressure increased, what are your plans for this?
    Chris.
    A3simon's Avatar
    Nov 2006
    Aberdeen
    976
    Its already been remapped so i guess they were increased then
    Learning to fly 3D
    Jan 2007
    Essex
    195
    No, your remap is designed for a standard intercooler. An intercooler reduces the temprature of the intake charge, which will produce more power, however the main reason for reducing the temprature of the intake charge is to offset the start of detination. So if you reduce the intake temps you will gain a few bhp, but if you combine this with a boost upgrade then you will see significant gains.
    I am no longer a modifier, but if it where my money I would only combine this type of mod with, bigger turbos, strengthened and lightened internals etc, but I would also have a 300 + bhp figure as a planned target.
    Hope this helps
    Chris.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    You'll still be running higher boost with a remap though.
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Learning to fly 3D
    Jan 2007
    Essex
    195
    Quote Originally Posted by DPM
    agreed, thats where the power gain comes from with a turbo remap, but it will be within the safe levels for the factory intercooler, not the safe levels for the upgraded intercooler.
    You will also see a gain if you just fit the upgraded intercooler, so in the middle of summer your engine will feel like it did in the middle of winter with the standard intercooler.
    Chris.
    A3simon's Avatar
    Nov 2006
    Aberdeen
    976
    So it is worth it then
    Boydie
    you may have to go back to whoever remapped your car and get them to fine tune it to accomodate the FMIC
    are you planning in getting an exhaust? if so, wait until then and get it mapped again with the FMIC and exhaust and you will get better gains and it will be healthier for your car!
    Learning to fly 3D
    Jan 2007
    Essex
    195
    Quote Originally Posted by A3simon
    750, for a small gain, when you compair your chip which gave 40 bhp for 300 - 400 makes it look expensive, so on its own I would say no. But as part of a further plan to upgrade performace, i.e. possible engine internals, and a further boost upgrade, it may even become an essential to prevent detonation.
    Chris.
    Boydie
    even with just a FMIC, full system exhaust (turbo back), down pipe, some sort of forced air induction, dump valve, with a custom remap for these mods you should see an increase of maybe 45-55bhp
    will be expensive but you will have a very fast and efficient a3!
    A3simon's Avatar
    Nov 2006
    Aberdeen
    976
    At the moment it has 253bhp thanks to AMD custom remap, Cat back milltek, Forge DV, K&N panel filter and carbonio cold air feed. Im considering the turbo back exhaust but that is all the mods im doing all i want to know is will it have a negative effect fitting it i.e. will it cause any problems not whether people think its alot of money
    Learning to fly 3D
    Jan 2007
    Essex
    195
    No only a positive effect. As I said in my previous post, if you fit this intercooler, your intake charge will have the same temps in summer as a standard intercooler will have in winter.
    Chris.
