Badger5Volks Autos
Page 3 of 3 FirstFirst 123
Results 81 to 118 of 118
Like Tree17Likes
Thread: 8P Frequently Asked Questions (FAQs)
  1. #81
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    How to tell the difference between 3dr/5dr/cabrio rear bumpers when buying...
    When buying rear bumpers here is how to tell the difference between 3dr, 5dr and cabrio.
    First 3 digits of part number: 8P3 is for a 3 door, 8P4 is for a 5 door..... AND 8P7 is for the cabriolet (be careful, there are a lot of cabrio rear bumpers floating around on ebay which are being advertised as 3 door!)
    The easiest way to tell the difference between the three different types is..... the edge which meets the rear lights is flat for a 3dr, whereas the 5dr has an angled bit, and the cabrio bumper looks like the 3dr bumper but has a screw hole either side of where the tailgate closes.
    3 door:
    5 door:
    Cabriolet:
  3. #82
    warren_S5's Avatar
    Oct 2007
    7,158
    Technical Service Bulletin
    S3 2.0T Exhaust Springs too short in 2008 cars
    TSB File
    Audi S5 3.0V6T Coupe Black Edition
  4. #83
    warren_S5's Avatar
    Oct 2007
    7,158
  5. #84
    warren_S5's Avatar
    Oct 2007
    7,158
    Changing your suspension set up? Here are some technical considerations for you to consider for alignment:
    https://picasaweb.google.com/lh/phot...eat=directlink
  6. #85
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
  7. #86
    The Engineer's Avatar
    Apr 2011
    Mid / Northwest
    336
    I found this on an ebay listing and thought it would help...
    VW Audi Seat Skoda Part Numbers Explained
    VWG (Volkswagen Group - VW, Audi, Seat, Skoda) part numbers may look confusing to the untrained eye but they do in fact tell you a lot about the part and even the car it is used on!
    This guide will hopefully provide ASN users with help in determining what the VWG part numbers mean and provide help when searching for part numbers for your car.
    The VWG part numbering system is a very logical sequence of numbers and letter, almost a language in itself. Once you understand how a part number is made up, you could almost guess what a part number would be!
    A typical basic VWG part number consists of a 9 digit block which in turn contains three seperate 3 digit blocks.
    A typical VWG part number looks like this: 1J0821021
    This can be broken down into the three 'lots' of the digits, i.e.:
    1J0 821 021 - Each group of three digits has a specific meaning:
    1J0
    N.B. All VWG cars have a specific chassis model code. Please see our separate MODEL CODES GUIDE for further information on the various VWG chassis models codes.
    1J is the model code for the car the part fits. In this case, 1J is a MK IV Golf. Sometimes when a part is different for left hand drive cars or right hand drive cars, the third digit will denote either LHD or RHD. A 1 would indicate the LHD and a 2 would indicate RHD.
    So:
    1J1
    = a LHD specific MKIV Golf part
    1J2 = a RHD specific MKIV Golf part
    1J0 = Not specific to LHD or RHD models
    Another way the first three numbers are used is when the part is different for various body versions of the same car.
    i.e.:
    1H0 is MK3 Golf
    1H9 is MK3 Golf Estate
    3B5 is Passat Saloon
    3B9 is Passat Estate
    N.B. For certain engine and gearbox parts the first three digits of the part number do not denote the model code but the engine or gearbox the part is used on. An example of this is a part starting 02A is used for 02A gearboxes or a part starting 058 is for VWG 1.8 petrol turbo engines.
    821
    The next group of three digits 821 has two meanings.
    All VAG parts numbers are divided into 10 main groups and then into several sub groups. The main groups relate to the different vehicle assembly groups of the car as follows:
    1. Engine, Clutch
    2. Fuel tank and pipelines, Exhaust System, Air conditioning System
    3. Transmission
    4. Front Axle, Differential, Steering
    5. Rear Axle
    6. Wheels, Brakes
    7. Hand and Foot levers, Safety Covers
    8. Body
    9. Electrical Systems
    10. Extras, Accessories
    Our part number begins with 8. This means it belongs to group 8 which as we can see is 'body' and we refer to this number as the 'main group'. The 21 is the specific 'subgroup' of (8) body, and the subgroup 21 is always wings.
    The part number so far is 1J0 821 so we know already that is is a Golf MK IV wing!
    N.B. A part number that has a 98 as its 5th and 6th digit is a 'kit' part. i.e., it contains more then one part.
    An example of this is brake pads:
    1J0 698 151 M is a set of brake pads for a MKIV Golf.
    021
    The last three digits are the 'real' part number of every part.
    The last three digits in our example part number are 021.
    The number 021 has two meanings. 021 is the part number for a wing, also when a part is sided, i.e. left or right, the very last digit (1 in this case) denotes the side. An even number means right hand side, an odd number means left hand side. So in the example part number,021 is a wing and the side it fits is the left hand side (being an odd number).
    This is normally always the case with only a few exceptions.
    So our part is a left side wing for a MK IV Golf!N.B It should be noted that left and right are always used when viewed from the rear of the car.
    For the UK the left (passenger) side is nearside and right (drivers) side is offside. An easy way to remember is nearside is nearest the kerb, hence, nearside.
    Frequently there will be a tenth digit after the 9 digit block which will be a letter. This refers to either the versions of this part i.e. if different models have different versions of the part, or if a part has been superseded, this letter will increase along the alphabet to indicate that a supersession has taken place.
    An example of this:
    1J3 831 055 H
    - This is a VW Golf IV 3 door left side door. Note the 3rd digit refers to the 3 door model and the 9th digit is an odd number so this denotes left side. The tenth digit 'H' denotes the version of the door.
    1J4 831 056 H
    - This is the right side front door but for a 4 door model. Note the third digit refers to a 4 door model and the ninth digit is an even number so it is right side. Again the 10th digit denotes the version of the door.
    Finally, some part numbers will have a further 3 digit block which denotes a colour or interior trim code. These can be parts for the body or interior of the car.
    An example of this is:
    1J0 807 217 C GRU
    - This is a front bumper for a MK IV Golf. Note the 807 refers to Main group 8 (body) and subgroup 07 (bumpers) the 217 is the specific number, the C is the version of the part number. The GRU is the colour code. In this example GRU denotes 'primed' so the bumper is supplied primed.
    Another example is:
    1J0 857 311 A 01C
    - This is an ashtray for a MK IV Golf. The 01C is the interior trim code for black trim.
    Remember that very often VWG will use parts across a range of cars. So you may be as likely to find a part number beginning 1J that originated on the MK IV Golf on an Audi A3 or a Seat Leon.
  8. #87
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    The definitive 2009 led facelift guide.
    http://www.audi-sport.net/vb/sandbox...-facelift.html
  9. #88
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    Isnt this the FAQ?? should really make a thread specific to your problem rather than posting here??
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
  10. #89
    27,074
    Very true, I'll get it edited
  11. #90
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,890
    Guide: Removing A3 8P Seats
    Seat change guide
  12. #91
    Nov 2012
    ***8P Most Frequently Asked Questions (FAQs)***
    2004 a3 conversion to 2008/2012 s-line
  13. #92
    Nov 2012
    I know this questions been ask Many times but would like to know what's involved in 2004 a3 front end conversion to 2008/2012 s-line including the delivery headlights thanks joe
  14. #93
    Fossie
    Rhubarb Triangle
    3,969
    New bonnet, bumper, grille, wings, lights, coding and about £2000 !
    Do a search and look at the 'sticky' a few lines down detailing 2009 facelift. That will give you a clue.
    Someone may come along and give you more info. soon.
    EDIT: forget the 'sticky' just read all this :- Conversion from pre-facelift double grill bumper to facelift S-line bumper
  15. #94
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,382
    A3 Sportback 2.0TDI
    MODS:
    S3 facelift,
  16. #95
    Crunching The Gears
    Apr 2012
    Invergordon Scotland
    406
    Mods so far...
    LED Interior Lights, Front splitter, Cruise Control.
    Puddle/ Footwell Lights, LED number plate and side lights.
    75% Window Tints, MY11 Lights, Black Optics Grill.
    MFSW, Leather trimmed Grab Handles. CH/LH Lights
    JL Audio, DAB radio
    Vinyl wrap wing mirrors
  17. #96
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,425
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
  18. #97
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    8P2 S3
  19. #98
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Thought we had a "How To" thread on here, seems to have gone.
    Anyway, here's my facelift grille install guide - GUIDE: How to install/replace your front Grille - Facelift (8P3)
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
  20. #99
    mitalm's Avatar
    Audi A3
    Sep 2007
    Emsworth, Hampshire
    85
    Follow mitalm On Twitter Add mitalm on Facebook Visit mitalm's Instagram Channel
    Hi guys,
    I realise its not a guide in itself but here's a link I found to a literal TONNE of FAQ's and DIY guides/how to's for the A3 8P. Really handy, definitely easier to give it a quick browse and then search the forum for anything more specific that you can't find.
    Audi A3 TDI forum, DIY, FAQ, and "how to" index
    Enjoy!
    Sandra likes this.
    VW Golf MK1 Cabby 1.8GTI -Dark Green-Electric Hood-Swage Line Smoothed-Scorpion Exhaust-Central Locking-Cobra Alarm-Hilariously Low-Mini Starmags - FOR SALE!
    Audi A3 2.0TDI S Line
    -Akoya Silver-Xenons-Heated Half Leather Seats-Rear Parking Sensors-Dual Zone Climate Control-Armrest-Vortex Rear Spoiler-18" 5 Spoke Star Alloys-Non-smoking Pack-All Factory Spec!
    I'm a stickler for 50+mpg, anything above 60mpg and I might...
    Anything below 40mpg and I know I've had a good drive!
  21. #100
    Jan 2014
    7
    Swapped my heated cloth seats for S3 leather seats... They will not turn off.. Constantly hot all the time !!! What is causing this ;(
    Using Tapatalk
  22. #101
    london jay's Avatar
    Sep 2013
    84
    Air vent mod
    Good morning!
    I just thought I'd show my small mod I did with the dash air vents.
    Replacing the 4 standard one's with TT mark 2 ones.
    I found them online for £10 each.
    Surprisingly it only took me about 10 mins to do and was really easy.
    Cheers for looking!
    Jay.
    voorhees likes this.
  23. #102
    JackJones's Avatar
    Mar 2014
    44
    They look nice but I don't know if I feel that they are nice enough to go through all the effort and money, not that it's lots of either but I think the originals are nice anyway.
    Using Tapatalk
  24. #103
    Apr 2014
    50
    General question as I'm curious... Does the A3 manual transmission have a "sport mode" or is it just the DSG transmission cars that do? If so, what year car?
    Using Tapatalk
  25. #104
    london jay's Avatar
    Sep 2013
    84
    The manual wouldn't have a sport mode because all sport mode does is keep the car in gear until it nears the maximum rev before changing up. Giving you quicker acceleration if I'm not mistaken?
  26. #105
    Apr 2014
    50
    Ohh right thanks! Any idea on how to make the Audi go and faster? I have an A3 1.4TFSI
    Using Tapatalk
  27. #106
    london jay's Avatar
    Sep 2013
    84
    Get in touch with AmD Tuning - High-performance vehicle tuning, ECU remaps, Exhausts and Servicing they can advise you about what you can do mate
  28. #107
    Apr 2014
    50
    Thanks mate! Which Audi do you have?
    Using Tapatalk
  29. #108
    london jay's Avatar
    Sep 2013
    84
    No worries Calvin. Mines a A3 3.2 v6
  30. #109
    Apr 2014
    50
    Sickkk! I want an S3 as my next car, just sticking with this 1.4TFSI to build up my no claims as I'm 20 you see! What previous cars do you have? My dad has an A4 Avant Quattro Sport!
    Using Tapatalk
  31. #110
    london jay's Avatar
    Sep 2013
    84
    Yea, I'd like an S3 too mate!!! Before this motor I had a civic type R and before that a 306 gti6, which was my fave!!
    Like you say, insurance is a killer!!!
  32. #111
    Apr 2014
    50
    Jeez you've had quite a lot of decent cars! How old are ya?!
    Using Tapatalk
  33. #112
    london jay's Avatar
    Sep 2013
    84
    I'm a old git now 35 lol
  34. #113
    Apr 2014
    50
    Lol so insurance would be alright and cheap for you right?
    Using Tapatalk
  35. #114
    london jay's Avatar
    Sep 2013
    84
    A lot cheaper than it used to be yea!!
  36. #115
    Apr 2014
    50
    Lol you have Facebook or twitter?
    Using Tapatalk
  37. #116
    Apr 2014
    50
    Hi, can anyone send me a useful eBay link on the best/reliable S Line grill badge that I can buy?
    Using Tapatalk
  38. #117
    dannyAshcroft89's Avatar
    Feb 2014
    105
    Does anyone know if you can fit a dump valve in the s3? Some peopke are telling me you cant!
    Using Tapatalk
  39. #118
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by dannyAshcroft89 View Post
    See my 'build thread' in my sig. You can.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
  1. 8P Frequently Asked Questions (FAQs)
    By marriedblonde in forum Sandbox
    Last Post: 28th May 2012, 12:33
  2. This may be the most stupid of questions!!!!!
    By nhowroyd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2009, 14:11
  3. A3/S3 FAQ - Look here first before posting questions
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2005, 09:32
  4. Questions to ask service techs
    By octagon in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2004, 18:53
