Err, how on earth do you change headlight bulbs? The instructions in the manual are clear enough but, once I've removed the outer cover at the back of the unit, the inner mount which holds the bulb is so far inside I can't even see it. Are you supposed to do this by touch? My concern is that I'd be able to get it out by feel alone but then wouldn't be able to get it back in and would end up stuck.
