JMB RetrofitsChris Nott
Results 1 to 13 of 13
    cliveywolves's Avatar
    Jan 2007
    229
    A3 Sportback Roof Rails/Bars
    HI All....
    Anybody know if you can retrofit the Chrome Roof Rails/Bars to a 2007 A3 Sportback ???
    Wish i had factory ordered them now but was trying to keep the costs down ........
    Clive
    Woodster's Avatar
    Welcome to my world...
    Dec 2003
    Mighty Mighty Yorkshire
    83
    Hi Clive,
    It does look like you can get them http://www.audi-accessories.co.uk/in...&productId=213
    ...but it comes with a CD ROM of fitting instructions!! :O So your guess is as good as mine as to how long they take to fit and how much of the car you have to dismantle!
    Rich
    2005 Black A3 2.0T FSI S Line DSG
    Centre Armrest | Folding Mirrors | Symphony | Heated Seats | Parking Sensors | Xenons | Light Pack | Alu Pedals | Headlight Protectors | Mud Flaps | Mats
    2007 Red Yamaha YBR125 ...soon to be a Triumph Sprint ST :D
    TVR Chimaera 450
    http://woodys-tvr.blogspot.com/
    southpaw66's Avatar
    Nov 2006
    UK
    167
    I think you'd need to drill some holes... I wouldn't like to try.
    A3 Sportback 170TDI quattro S-line
    Lava Grey, SymphonyII, BOSE, Light and Rain Sensor Pack, I-POD connection , MF Steering Wheel, Rear Parking Sensors.
    Jan 2007
    229
    cheers lads...
    looks like to much work for me.....
    and more expensive then i thought would be...
    Oct 2006
    246
    Quote Originally Posted by cliveywolves
    HI All....
    Clive
    I have them fitted to mine and had a good nosey at them out of curiosity as to how they are fitted. There are no fixings visible from the exterior at all and thus considering the load that could be placed on them I assume they must be bolted from the inside under the roof lining.
    Not a job for the faint hearted!!!
    Aug 2006
    41
    The roof rails are attached to the roof using 4 special bolts,
    these are fixed through the 4 holes drilled at the factory when they are fitted, to retrofit them you would need to remove the side curtian airbags to get access to the bolts to tighten them up and you would also need to drill the roof panel which would them void your corrision warrenty
    cheers
    Andy
    wilko's Avatar
    Top Gear
    Feb 2005
    Nottingham (UK)
    724
    I'd speak to MarriedBlonde he might be able to get you some at a reasonable price from his supplier!!
    A3 2.0 TDI Sport in Akoya Silver - with... Black Alcantara, Black Headlining, Aluminium Inlay's, Interior Light Pack, Storage & Luggage Pack, Front Armrest, Electronic Climate Control, Non-smoking Pack, First Aid Kit & Warning Triangle, Electric Sunroof, Heated/Folding Door Mirrors, Sony CDX-GT930UI with USB iPod Connector & BOSE, 17" '5 Spoke Star' Alloys, Light & Rain Sensors, Xenons, Vortex Rear Spoiler, GTI Aluminium Pedals & Black Brake Callipers!
    giblets46's Avatar
    Nov 2006
    156
    i guess if you are only using them for...'decorative purposes' (they do look good though!) then it might be possible to use some sort of adhessive
    Any spelling/ grammatical errors are there purely to annoy!
    A4 2.0TDI (143) S-Line Quartz Grey
    Aug 2006
    147
    Definitely not an item to retrofit IMO.
    Just out of interest why do you want them. Beuaty is in the eye of the beholder but I think they look horrible, spoil the lines of the car and give it an estate car look. I'd pay to have them removed.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Is it possible to retro-fit them to the open-sky system, as there is the glass panels aligned for the space on the roof?
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    Dec 2004
    287
    Quote Originally Posted by roadrunner
    That'll be why Audi make an Official Retrofit kit for them then...?
    Fitting tme is 300 TU and you don't need to remove the Curtain Airbags to fit.
    2008 VW Golf R32 3dr
    DBP :: RNS510 :: Winter Pack :: Retrofit Cruise :: OEM LED Tail Lights :: R-line badges ::
    Aug 2006
    147
    Quote Originally Posted by Nelson_Wilbury
    Just becaue they make a kit doesn't mean the time, effort, cost and risk makes it worthwhile for the end result... IMO. Obviously you think differently because you value the look of roof bars.
    giblets46's Avatar
    Nov 2006
    156
    Was in WHSmith the other day, and there is some Audi drivers magazine,a nd has an article on roof bars,a nd how the A3 ones are fitted, which is basically through the roof, then some beam underneath?
