AH FabricationsChris Nott
Results 1 to 9 of 9
    Jan 2007
    Renfrewshire
    118
    Xeon Convertions
    Hi All,
    I've bought a set of Xeon convertion kit For my A3 55 Plate.
    I'm Having a bit of problems fitting them, All was going fine untill i switched the engine on then after 4-5 seconds they start flickering like mad!
    When connected straight over the battery, they are fine or when the engine
    aint running.
    So i connected a relay in the circuit and took a supply straight from the battery (via a fuse). But now the resistance of the coil must be too high and the D.I.S show's up a lamp fault.
    So question really?
    I'm i right in saying there is some sort of weird energy saving circuit built into the supply to the headlights? and if so can it be switched off/disabled?
    If not i'll have to put the relays in and get resitors to match the resistance of a 55w halogen lamp, i dont really want to do this cause it gets a bit messey.
    Help is much appreciated!
    Thank Ross
    Aug 2006
    119
    exactly the same thing happened to my mate with his BMW 325. He took it to bmw to have it plugged in, they had to reprogram something to do with the light switch.
    I guess something can be sorted with VAG COM. Have a search around these forums and if no joy go check out the BMW forums.
    but dont worry, it can definetly be sorted.
    Perhaps the circuit is design to make like difficult if you fit illegal Xenon coversion kits !
    Have a look at the following thread: Retrofitted OEM Xenons
    Dave R (h5djr)
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Ross it is the same problem with Merc's I bought a set and had the same problem. It's to do with the voltage drop apperently. Yes there is something that can be coded with vag-com.
    The alternative is to use a relay like you said.
    J.
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    Beddie's Avatar
    Dec 2006
    239
    Hiya mate
    The same problem crops up on retro-fitted xenon kits on the MK5 golf..
    The problem lies with the fact that your car has the vag-com settings for a halogen equipped car and if you measure the voltage at the headlight plug you will find it to be around 10.6VDC iirc which is fine for a halogen bulb but too low for a HID ballast to maintain a constant arc..
    If you change your vag-com setting to 'xenon equipped' the voltage at the plug will increase to 11.5VDC and this will provide the correct voltage for your HID kit..
    You may still find you get a bulb failure warning on the DIS though as the HID current draw will be in the region of 35W, much lower than the standard 55W halogens although whether the vag com change will clear this also as the car will then be expecting a lower load on the headlamp circuit?
    You can get kits to get around the flickering/bulb warnings on the modern VAG stuff if you don't have vag-com, here's a link to a company that do them, look for 'filter-kits'
    www.hids4u.co.uk
    Steve
    Beddie's Avatar
    Dec 2006
    239
    D'oh! Just looked and hids4u have stopped selling the filter kits seperately and now bundle them with their own kits...
    Jan 2007
    Renfrewshire
    118
    Quote Originally Posted by Beddie
    Thanks,
    Yeah i was just looking my self and couldnt find it. Thought i was incapable for a minute
    Beddie's Avatar
    Dec 2006
    239
    Lol sorry about that Ross
    Just been reading his site and he says he's fed up with selling fixes for other kits so has withdrawn the filter kits and now offers a 75 trade-in against his 'ultimate kit'...
    I read that as ' I'm fed up of people buying other people's kits and only buying the 30 'fix' from me, so i'll force them to buy the lot...'
    Jan 2007
    Renfrewshire
    118
    Well to be honest that is fair, that must piss him off!
