JMB RetrofitsSky Insurance
    cliveywolves's Avatar
    Jan 2007
    229
    RNS-E Install Help Please.....
    HI ......
    Just about to retrofit a rns-e unit into my 2007 A3,
    I need some on advice on were to place the GPS Antenna, I have
    seen some sites saying to remove the glove box and fit above that
    but i dont really wont to remove any parts as the car is so new.....
    Any ideas were would be best to fit it please and were have you got
    yours in the car....?
    cheers........
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    Clive,
    I tried installing it in at the back of my RNS-E but you will only get about 3-4 satellites, out of a possible 8.
    I too was a bit reluctant about taking the glovebox out, but it is really so simple as you can see in the earlier thread. And there are loads of metal areas in there to attach the magnetic base of the gps module to.
    It is 100% worth doing this as I always have 8 satellites most of the time. The glovebox goes back in so easily as well and leaves no trace!
    If you need more help just give me a shout!
    Terry
    57 Plate Imola Yellow S3
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    Hi Clive,
    I have mine currently on top of the glovebox (it might have been my own guide you read!), but I'm gonna have to move it again as the reception isn't great. Like Terry, I noticed there's more space behind the glovebox so next time I'll put it in there.
    Ideally though the best thing to do is get a sharkfin antenna to go on the roof at the back of the car. Not only does this guarantee the best possible satellite reception, but this is how Audi supply the A3 with the RNS-E; the sharkfin comes as standard. So your retrofit would be factory-perfect, if you see what I mean! OE sharkfins go on eBay from between £30-£60, and longer term this is definitely something I'm going to look into.
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    Jan 2007
    229
    Quote Originally Posted by benw123
    Hi Clive,
    Ideally though the best thing to do is get a sharkfin antenna to go on the roof at the back of the car. Not only does this guarantee the best possible satellite reception, but this is how Audi supply the A3 with the RNS-E; the sharkfin comes as standard. So your retrofit would be factory-perfect, if you see what I mean! OE sharkfins go on eBay from between 30-60, and longer term this is definitely something I'm going to look into.
    thanks for the info...
    so you say you have it on top of the glovebox at the moment, did you have to remove the glovebox to do that ???? or did you just place it on it when you fitted this rns-e unit ????
    let us know how the re fit behind the glovebox goes.......
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    Yes, I had to take the glovebox out, but it is amazingly simple. If you click on the "RNS-E Sat Nav" link in my signature (below), there's instructions with pictures. It really is very easy and even a DIY beginner could do it!
