EM TuningChris Nott
Results 1 to 18 of 18
Thread: lowering...
    trev_tang's Avatar
    05 A3 TDi sport (140)
    Jan 2007
    14
    lowering...
    After reading threads about anti-roll bars and coilovers im slightly off about lowering my A3. I was tempted to buy a set of Fk coilovers and it said something like this on the site (Height adjustable (both axles), TUV approved. Wheelspacers might be necessary when using standard rims. If drive shaft diameter more than 42mm FKPSW01 required)
    What is all this about??? Also i heard that a set of aftermarket anti-roll bars are needed. Can anyone explain this to me??? Im looking to lower the car as low as possible on 19'' RS4's. Are camber kits needed also, cause when i had the civic, i needed to buy a camber kit because the cars wern't adjustable. Anything would be greatly appreciated!
    mjepson's Avatar
    Dec 2006
    175
    I guess they recommend spacers because the tyre will touch the inner wall if you lower it very much. Normal wheels have a very high offset on the A3, ET50, and the 19" RS4 are probably not far off.
    I would just buy the FK (allthough i would opt for KW instead) and see if the height you set it to touches the inner housing.
    The Roll bar should not be required
    Audi A3 8P 2.0 TDI S-Line Lava-grey // BBS CK 8x19 ET44 // 215/35 R19 Dunlop Sport FM901 // Eibach Sportline 50/40mm // Bluefin
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    marriedblonde should be able to help with this - he's lowered his car and has spacers on the wheels too (I think).
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    tinka
    ive got a brand new set of kw springs that i never got around to fitting,still in box with invoice if you decide on springs,they lower 40mm,or 20mm for the s-line.
    trev_tang's Avatar
    Jan 2007
    14
    Mjepson...is thats ur car on ur avatar??? If so how low is that and what have ya done to the suspension?
    Many mods to follow...
    mjepson's Avatar
    Dec 2006
    175
    No not mine, its a belgian A3 with Work wheels and airride suspension.
    From cleaned.be
    Boydie
    anyone got opinions on the eibach street coilover kit?
    compared to FK or KW?
    mjepson's Avatar
    Dec 2006
    175
    My opinion is that KW are the leaders when it comes to coilovers. I could not say if there is a big difference from FK or Eibach as they are well known names aswell, but i don't think you can go wrong if you go for KW.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Another thing is KW offer a great range for what ever your wanting from the kit!
    http://www.dpmautostyling.co.uk/cata...88_520_529_633
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Boydie
    i want lowness on 19" or maybe 18" alloys with comfort too
    dont want the boucny-ness i had with my Spax RSX coilovers in my clio :S
    john_cook's Avatar
    I was the STIG.
    Jun 2006
    Lancashire
    212
    i've not installed coilovers but have put 19s on my A3 with 30mm eibach spring drop. Not had problem with this. Have 10mm spacers on to help fill out the arches and again no rubbing issues.
    I do sometimes get a little rubbing on the front bumper with the tarmac (not the wheels) when going too fast over speed bumps, but i have a custom one fitted (Rieger). There was a guy called only1stefan on here with the rieger front bumper and 50mm drop. I don't know how he drove that thing without shaving his bumper on loose stone chips on the road!
    cooky
    trev_tang's Avatar
    Jan 2007
    14
    i don't know but im kinda on a budget so i can't really afford the KW's...
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    What about Weitec? Made and owned by KW but a cheaper option?
    DPM Performance
    T: 01207 561606
    mjepson's Avatar
    Dec 2006
    175
    I also wanted a cheaper option, to begin with atleast.
    Got myself the Eibach sportline springs on ebay.de for 150euros. They lower about 40-50mm on my s-line dampers.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    If your shocks don't have many miles on them and you aren't going to low then lowering springs are a good and cheap option!
    DPM Performance
    T: 01207 561606
    Boydie
    john cook - whats the ride like on the 19's?
    i had 18s and coilovers on my clio - ride was ok but bouncy at times
    not wanting the same again really, im liking the comfort of the tdi sport
    wilko's Avatar
    Top Gear
    Feb 2005
    Nottingham (UK)
    724
    Quote Originally Posted by Boydie
    "comfort of the tdi sport"
    That'll be a 1st!!
    A3 2.0 TDI Sport in Akoya Silver - with... Black Alcantara, Black Headlining, Aluminium Inlay's, Interior Light Pack, Storage & Luggage Pack, Front Armrest, Electronic Climate Control, Non-smoking Pack, First Aid Kit & Warning Triangle, Electric Sunroof, Heated/Folding Door Mirrors, Sony CDX-GT930UI with USB iPod Connector & BOSE, 17" '5 Spoke Star' Alloys, Light & Rain Sensors, Xenons, Vortex Rear Spoiler, GTI Aluminium Pedals & Black Brake Callipers!
    Boydie
    well i know its got harder suspension but compared to my old clio it is comfortable!
