Volks AutosEM Tuning
    S_Line's Avatar
    Feb 2005
    Norfolk
    74
    A After market Tow Bar on my A3 3.2 ? can it be done ?
    I was always informed that a aftermarket Tow bar cannot be fitted to my Audi A3 ?
    Is this right ?
    Has anyone had a aftermarket tow bar installed ?
    I have a A3 3.2 S-Line DSG
    would love a tow bar to pull a trailer or caravan
    is it possible with out buying a new back bumper ?
    regards
    Brian
    Impreza WRX, Impreza Type R, Impreza WR1.Audi 3.2 V6 DSG Quattro [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Track Days in all of the above.
    Aug 2006
    72
    After market towbar on A3
    Brian,
    I've just fitted a Bossal towbar (swan neck) with no problems at all,although you do have to cut the bumper a small amount.
    The only other thing is to purchase a dedicated wiring kit because of the CAN-BUS electrical system used in the A3.
    Regards,
    Scott.
    (8P)A3 2.0 TDI Sport-Dolphin Grey-
    1983 (DAC)Talbot Sunbeam Lotus - Weekend Toy.
    Dreaming of Boost
    Nov 2006
    VR6
    50
    This guy has come up with something. He is here in the US and I do not know if it would be work for the 3.2Q. It is worth a look.
    "Some of us are decent people who want to stay out of the emergency room, but still
    blast through neo-gridlock traffic in residential districts whenever we feel like it....
    For that we need fine Machinery." -Dr. Hunter S. Thompson (1937-2005)
    Dec 2004
    287
    It can be done to the 3.2Q no problem although if its a Quattro model modifications need to be made to the Quattro system so its not cheap.
    2008 VW Golf R32 3dr
    DBP :: RNS510 :: Winter Pack :: Retrofit Cruise :: OEM LED Tail Lights :: R-line badges ::
    Aug 2005
    Howden
    102
    Had a towbar fitted to my (sorry non quattro) Sportback a couple of years ago - took about 3 hours, inc electrics, they just removed the bumper internals and fitted a new stronger unit which incorporated the attachments. The exterior plastic bumper section was unchanged as far as I could see. Cost about 200. And don't fall for the dealers who tell you its a risk not using an Audi towbar - they are all made to the same spec in terms of strength and towing limit - mine towed a pair of racebikes at 90mph across belgium and germany on numerous occasions with no problems at all.
    http://www.ntta.co.uk/buyers_guide/g...aspx?Lookfor=5
    S_Line's Avatar
    Feb 2005
    Norfolk
    74
    mmm at least it can be done though
    Not sure about the changes to the Quatro system ? Unless its mechanical ?
