Sky InsuranceChris Nott
Results 1 to 10 of 10
Thread: Question ?
    Apr 2004
    North East, Norton
    34
    Post Question ?
    I admit I should probally look in the manual but I've noticed my econ button won't switch off!! just got my new A3 and have noticed they've made a few changes to them my last one was a 02 reg
    But will the econ not switch off as it's F*%king cold out there and it's automatic and just saves the air con cos my 02 never did that :s and has anyone noticed it doesn't do the wipe after the couple of wipes after you spray the front window screen with water or again is it just my car with a fault
    d3fy's Avatar
    Sep 2005
    Sheffield
    1,411
    Just press Auto I think to switch of Econ? And no there is not final wipe after spray
    2.0T Quattro SLine, now 320d Sport Touring
    Apr 2004
    North East, Norton
    34
    nope doesn't work tried that on the way home! going to admit defeat and look through the manual
    dmaudi's Avatar
    Apr 2006
    Hampshire UK
    209
    Yes Econ is off when you press auto and vice versa.
    d3fy
    mine does the extra wipe?,
    pretty sure it can be vagcom adjusted, to add or subtract
    I actually don't like the extra wipe my last two cars have done it and I like to decide when I've done enough wipes, usually end up with a smear
    I had mine open all the door on one press as that three click VAG nonsense winds me up,
    worth speaking to your dealer, IMO
    2012 Q3 S line S-Tronic 177 TDI
    2013 MINI GP
    Previously B8 S4, 8P A3 3.2Q
    Apr 2004
    North East, Norton
    34
    to the above no econ is on and so is auto but adjust the fan and auto is off with econ is still there :s
    dmaudi's Avatar
    Apr 2006
    Hampshire UK
    209
    Quote Originally Posted by duncangoncalves
    must be cold up your way, I think if you check your manual I remember something about you not being able to turn the ac on below a certain temperature
    2013 MINI GP
    dmaudi's Avatar
    Apr 2006
    Hampshire UK
    209
    one of us has got to wait to post an answer its like that two ronnies sketch where the answer is one question behind...
    sequence on mine is
    in auto, you can't fiddle with fan speed or air distribtution but you can have aircon off (press ECON)
    in auto as soon as you press any of the buttons other than econ it goes into manual
    hope that makes sense
    2013 MINI GP
    Vertigo1's Avatar
    Jul 2006
    2,485
    I have the "secondary" wipe after wash on mine and I can take it or leave it, don't know how the new one will be set up but it's programmable by the dealer or via VAG-COM if you want it changed.
    Regards the locking, as mine is a lease car and thus won't be sourced via a local dealer I've made sure the lease company forwarded my preferred locking configuration to Audi so the car comes set up this way. If they don't get it right then at least I have some come-back whereas otherwise I'd have to pay the local dealer to change it.
    Apr 2004
    North East, Norton
    34
    Just been reading the manual and it does say that IF the econ is still on over 5oC then you may have a fault with the air con well its 1oC up here so it'll wait and see just very noticed this with my 02 maybe it a update change they've made !!
    + the two ronnies sketch is good
    Dec 2004
    Portugal
    65
    I can tell you I had some problems with ac, and basically I noticed that because the econ does not goes off. Go to the dealer because almost for sure you have a fault. Basically if the system detects any problem with aircon it turns on econ all the time, because ac cannot be turned on.
