Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    Aug 2006
    11
    What's the main difference between s line and none s line?
    Especially in terms of handling on a 3.2.
    steeve's Avatar
    Nov 2004
    UK
    742
    I dont think there is any difference, the 3.2 gets the sports suspension as standard. I'm sure some one will correct me if I'm wrong.
    Steeve
    Vertigo1's Avatar
    Jul 2006
    2,620
    S-line is a styling pack over and above the standard Sport so there'll be virtually no difference to the handling. The only thing that will make a difference is the larger wheels (18" over 17" on the Sport). The 3.2 does get sports suspension as standard by virtue of only being available in Sport or S-line trim.
    S-line also gets you different front a rear bumpers, roof spoiler, half-leather seats, black headlining and s-line badges inside and out.
    Oct 2003
    South Wales
    2,942
    The S-line has different suspension over the sport (10mm lower IIRC).
    Dolphin Grey Audi S3 8P
    Vertigo1's Avatar
    Jul 2006
    2,620
    Quote Originally Posted by dickys3
    It does? I can't find any information to this effect on the Audi site. The price list PDF doesn't mention it either.
    Jul 2006
    160
    Yeah the S-line is lower then the 'Sport' if you look on the options list for wheels in the A3 spec booklet you will see that the Sport suspension isn't indicated as standard fit on the s-lines. So it must mean that they have a special suspension setup.
    Plus you can just about see it when the two cars are side by side.
    Apr 2006
    571
    Quote Originally Posted by Vertigo1
    Yes.
    In the A3 brochure it mentions that the S-Line is lowered a further 10mm over the Sport (which is itself 15mm lower than the SE).
    I've just switched from a 2.0TDI Sport to a 2.0T S-Line. The S-Line suspension is slightly firmer, though still comfortable on most surfaces.
    steeve's Avatar
    Nov 2004
    UK
    742
    Quote Originally Posted by A3_3.2_S-Line
    I'm sure that the 3.2 already has the Sport suspension, its only the cosmetic items and the 18" wheels that change. All 3.2 are classed as 'sport'. I just dug the brochure out for mine and it mentions that the suspension doesnt get altered. Thats a 2005 brochure.
    All the others do get the lowered suspension but NOT the 3.2.
    Steeve
    Spook's Avatar
    Mar 2006
    UK
    211
    OK then, I'm thinking of replacing my 2000 S3 with an '05 3.2 S-Line.
    Can anyone comment on how different the ride and handling of the 3.2 S-Line is, compared with the S3? Would I notice the difference and be disappointed with it after the S3?
    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    I think you'll find the 3.2 a bit clumsy compared to your S3, but you'll love the sound (once you've Miltek'd it )
