Badger5EM Tuning
Results 1 to 11 of 11
    Jul 2006
    91
    How accurate is the A3 speedo
    As the title says, I know most speedo's read under but curious to know if anyone has tested the accuaracy at varying speeds primarily 60, 70 & 100mph ?
    A3 2.0T FSI Quattro Sport
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,678
    If you have a Road Angel or sat-nav, or anything with GPS functionality, you should be able to display your real speed, & compare it with the speedo. They usually update around every three seconds, so there's alway a bit of lag when accelerating, but once your speed is steady, you can compare directly. When my GPS is showing a steady 70mph, the car speedo is reading 73.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Vertigo1's Avatar
    Jul 2006
    2,633
    Speedos always over-read, never under. Mine is about 10% out, so 100mph indicated is 91 actual and 127 actual is 140 indicated.
    bobtooke's Avatar
    Apr 2006
    UK
    Mine is about 5 to 6 % out from my GPS (ie at an actual 70mph shows 73/74-ish). This is about average for most modern cars.
    Mon-Fri: A3 Sportback SE 2.0 TDI, Dolphin Grey, Beige Vienna Leather, MF Steering Wheel, DIS, Heated Folding Mirrors, Comfy Mats etc etc
    Sat-Sun: Midget 1500 EFi, Vermillion, Black Vinyl (yuk)
    dmaudi's Avatar
    Apr 2006
    Hampshire UK
    209
    my understanding is that legally speedo's have to read over, I think it is 6%, totally agree with the numbers, I've seen mine go past 160 yet my SatNav says max attained is 143 or 146, can't remember exactly from my desk,
    does that also mean the odometer reads over or is that accurate? otherwise we're all getting less miles out of our cars than we think....
    anyone know if the speed limiter's based on speedo speed or true speed?
    2012 Q3 S line S-Tronic 177 TDI
    2013 MINI GP
    Previously B8 S4, 8P A3 3.2Q
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    In mine, speedo reads 70MPH when sat-nav displays 68MPH so approx 3% over-read here.......
    987 Boxster 2.7 (05) - Current
    A3 2.0T Quattro S-Line (55) - gone
    S3 Quattro (02) - gone
    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    mine is exactly 5% over.
    Nov 2004
    South East
    317
    Mine seems almost spot on at lower speeds, using those speed warning radar signs that flash your speed when you go past.
    Also, I read that the 3.2 does 24.7mph / 1,000rpm in 6th, which makes my 100mph at 4,000rpm seem pretty accurate. Same for top speed - 159mph in Germany - still creeping up slowly then a noticeable stop at about 6,300rpm, which means only about 3mph out compared to the limiter's supposed 250kph / 156mph.
    2006MY A3 Sportback, 3.2 SLine, Manual, Brilliant Red
    Aug 2005
    Cambridge & London
    21
    Mine is about 10% and consistent with slow and fast speeds. I am shocked by this tolerance and questioned it with Audi UK - they simply said that 10% was within their acceptable range.
    I told them that 10% tolerance is historical from the old cable driven speedos and that I do not consider it to be acceptable on a modern car where the speedo is electronic.
    We agreed to disagree in the end
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    I'm sure there was another thread about this not so long ago...
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    Dec 2004
    Sunny South Coast
    4,368
    Quote Originally Posted by da3m
    We do not know our car's true spped. We can get pretty close with a sat nav unit (accurate to approx 0.1%)
    There's lots of variables to consider regarding our speedo's. New compared to old worn tyres will have an effect. Under/over inflation will obviously effect the speedo reading. The theres the plethora of tyre manufacturers out there. Although the tyres same they are the same size the circumference is different from make to make.
    To give an example of the difference of a new compared to old tyre:
    If a new 225/40/18 tyre has a diameter of 637mm the circumference is 2000mm (I am using pi at 3.14 for these exmaples so not 100% accurate but will give you an idea)
    So that tyre has 8mm of tread say. When worn to the legal limit the tread will be 1.6mm so the diameter is now only 622.2mm and therefore the circumference is now 1953.7
    The difference as a % between old and new is 2% thats without taking into account for tyre inflation. So if your speedo is overreading by 10% with a new tyre it will be over reading less with a worn one.
    J.
