EM TuningAH Fabrications
Results 1 to 17 of 17
    Apr 2006
    england
    754
    dump valve on TDI
    has anyone fitted a dump valve on a 2.0 tdi
    tinka
    there is'nt any benefit by fitting one to a diesel,i believe?,a dump valve is only beneficial,because on a petrol engine,when the throttle valve is closed(when changing gear),the pressure build up will slow the turbo down,the dump valve will release this pressure,and keep the turbo spinning,
    a diesel does'nt have a throttle valve,it just sucks air straight in to the combustion chamber,so when changing gear there is nothing,(throttle valve) to slow the turbo down.
    Mar 2003
    UK
    426
    So where does the air go when you are changing gear - when it is not needed in the cylinder - but the turbo carries on spinning?
    tinka
    into the other cylinders,it will slow it down a bit,but,on the petrol the sudden closure of the throttle is what slows down the turbo,there is nothing on the diesel that closes abruptly,other than the valves,and there are 4 or 8 inlets (4 cylinder)so the build up isnt as great as there will always be 1 or 2 valves open at any given time,
    im probably not explaining it very well,but thats roughly why a dump valve will not realy work on the diesel.
    tinka
    Red face
    well,i may have to eat my words,i just did a google and found some diesel dump valves,http://www.dervdoctor.co.uk/ although they work electronicallly,via throttle position etc.
    icenutter's Avatar
    Jun 2006
    595
    Quote Originally Posted by tinka
    Whether or not they work is another matter though
    mikep's Avatar
    Jun 2003
    Wetheringsett, Suffolk
    591
    They are purely there to make the Chav 'Woooosh' noise, they do nothing for the performance of the engine other than probably make it worse.
    This is a bad thing.....
    I stongly advise against, unless you want to sound like a Chav......
    Pragmatik ICT
    Revo (VAG & Porsche) & Steinbauer Dealer for Suffolk & N.Essex
    A3 Sportback 2.0TDi Sport DSG Revo Stage 1 & 2
    Porsche Boxster S Revo Stage 1
    Nov 2005
    lothian
    181
    Hmm. marketed for Chavs too:
    "Our kits are the loudest available or your money back!"
    Oh dear....
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    LOL...Thank god someone mentioned chav!
    J.
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    tinka
    as i thought at the start,a waist of time on a diesel,although they probably come in burbry(is that how its spelt),or with a free burbry scarf and cap.
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    Having said all that, I've noticed there is a "TISSSSSHHH" noise when you change gear, suggesting that the excess pressure is being blown off somewhere.
    I've only heard it because a couple of times during the recent hot weather I've driven off with all the windows down. If you go full throttle in 2nd or 3rd and change up, it's very noticeable.
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    Mar 2003
    UK
    426
    Yep, I've heard the same (sounds quick cool for a diesel!) - and more so since I've had mine chipped.
    The pressure generated by the turbo has to go somewhere if you're not using it. It can't see how it can go into the other cylinders, as your foot is off the throttle and there is no need for it. So where does it go?
    tinka
    when your foot is off the throttle,the valves are still working,so are the pistons,it just wont be injecting diesel,there will be some pressure,but not as much as a petrol,because of the lack of throttle valve,im sure someone with a bit more knowledge of this will explain?.
    S_Line's Avatar
    Feb 2005
    Norfolk
    74
    no one buys a Dump Valve to add performance :lol: take a look at the Scooby boys !!
    Impreza WRX, Impreza Type R, Impreza WR1.Audi 3.2 V6 DSG Quattro [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Track Days in all of the above.
    Mar 2003
    UK
    426
    So, is a dump valve superfluous? Would the engine work just as well without one?
    S_Line's Avatar
    Feb 2005
    Norfolk
    74
    ahh many a debate about this on the Scooby Forums,
    Basicly its suposed to keep the turbo spinning, so enabling faster gear changes and instant power back on the throttle.
    bobtooke's Avatar
    Apr 2006
    UK
    On a petrol car, the dump valve releases the pressure which would otherwise hinder the engine and turbo on closed throttle by stopping the turbo from spinning due to high back-pressure. It also allows you to slow down - if you didn't release the pressure, the differential between either side of the throttle butterfly would be so great that the gas would bleed through. This would mean that when you take your foot off the gas, the car wouldn't react straight away and you may plough into a tree!
    The main advantage of aftermarket dump valves (recirc ones rather than chav atmos ones) is that they have a quicker reaction time than oem units which helps reduce lag when you go back on the gas by keeping the turbo spinning faster and longer.
    The VAG turbodiesels do have a pressure relief valve to avoid back-pressure but it doesn't work in the same way as a dump valve. I believe it's controlled by the ECU on a solenoid type arrangement.
    We need a Turbodiesel engineer in here.....
    Mon-Fri: A3 Sportback SE 2.0 TDI, Dolphin Grey, Beige Vienna Leather, MF Steering Wheel, DIS, Heated Folding Mirrors, Comfy Mats etc etc
    Sat-Sun: Midget 1500 EFi, Vermillion, Black Vinyl (yuk)
