AH FabricationsVolks Autos
Results 1 to 20 of 20
    Jan 2005
    Sheffield UK
    136
    Instrument lights
    After months of looking at my dials and deciding if they are lit or not I have come to the conclusion that there is light sensor which determines light and level during the day when the side lights are off. Now this system seems to work the wrong way round, surely the dials should light up in the dark and dim in the bright sunligh, mine don't they work the other way round. Is this a fault or design feature?
    Jun 2003
    World of my own
    9,813
    Re: Instrument lights
    Eh? You need more light in the sunshine, and less when it's dark i.e. your head unit dims when the lights are turned on so it doesn't ruin your night vision.
    Jan 2005
    Sheffield UK
    136
    Yes and I know I'm probably been thick but the way dials are set out means they require a different form of lighting to say an headunit? It would seem more obvious that in the dark the dials would require backlight whereas in the sun you can see them (i.e. they don't rely on contrast as much as say an lcd screen)
    daveflynn's Avatar
    Aug 2005
    Lincs
    49
    Normally in all cars the instrument cluster is always lit.
    When the headlamps go on the instrument cluster lights are dimmed, often the ICE will also dim. This is so you can see in the dark.
    Our eyes work better in the dark if there are no bright lights, hence the reason that you don't drive with your interior lights on.
    If there is a lot of contrast, ie bright and dark, the detail and depth of vision is reduced as your iris will close.
    My PDA satnat has to have the same done, very bright in day, almost off in dark, so I can see the road, as I am not yet a Jedi [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Eeef's Avatar
    Lord of War
    Nov 2004
    South Coast, land of the white man
    1,602
    It takes a whilew to suss out what they are doing [img]/ubbthreads/images/graemlins/wink.gif[/img]
    1) They are lit during day light, to counteract the shading of the console and possible low(ish) level light that doesn't require headlights.
    2) Then when the light drops below a certain level the dash lights drop further so the driver is aware it's getting dark and needs to put there headlights on.
    Stage 2 is missed out if you have the auto headlights.
    Dec 2004
    Chester
    247
    Mine do odd things with the auto headlights, just around the corner from where I live the road is quite dark due to overhanging trees, depending on the ambient light before I enter this "tunnel" sometimes the headlamps pop on but the insts only light up the pointers, with no backlight at all.
    Other times the headlamps don't come on but the whole instrument panel is lit up.
    I know later cars have different auto lights programming, early cars like my first A3 8P would be putting the headlamps on/off far too frequently, quite dangerous really, sometimes only coming on for about 15 seconds
    Perhaps in the not too distant future when we all have to drive with our headlights on all the time, some of these problems will go away.
    Mar 2006
    570
    [ QUOTE ]
    ...I know later cars have different auto lights programming, early cars like my first A3 8P would be putting the headlamps on/off far too frequently, quite dangerous really, sometimes only coming on for about 15 seconds
    [/ QUOTE ]
    My auto lights and instruments also behave like this, and my A3 is an 06 reg. I don't use the auto setting any more.
    Jan 2005
    Sheffield UK
    136
    Thanks for the replies so far but...
    In the dark (my garage) the instrument lights are off and in bright sunlight they are on which I don't get. Surely it would be better for them to be on in the dark so I can see the dials and off in bright sunlight where I can see them due to the sunlight.
    Jun 2003
    World of my own
    9,813
    So are you saying you can't see the dials at all at night?
    That's obviously not right. But if they just dim at night then that's how they're supposed to be, you can increase the brightness using the left hand stalk, maybe someone has just turned it right down low, and with headlights off this setting is bypassed
    Eeef's Avatar
    Lord of War
    Nov 2004
    1,602
    left hand stalk? It's a twidly dial on the dash for me mate. Next to the height adjusters.
    Jun 2003
    World of my own
    9,813
    I stand corrected, sorry was thinking of my A4
    imported_Redwing289
    If you're in the dark and don't have your headlights on the instrument lights will go off as a reminder to turn your headlights on.
    Eeef's Avatar
    Lord of War
    Nov 2004
    1,602
    ? [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    wilko's Avatar
    Top Gear
    Feb 2005
    Nottingham (UK)
    724
    [img]/ubbthreads/images/graemlins/bang.gif[/img]
    imported_TuffLittleUnit
    [ QUOTE ]
    [/ QUOTE ]
    I have a mate who's convinced that in the not too distant future the government will nanny us into wearing crash helmets in cars.
    I guess the upside to this is that I won't get annoyed at women missing green lights because they're putting their lippy on or watching the guy in my rear view mirror pick his nose then eat it.
    Jun 2003
    World of my own
    9,813
    It'll never happen as they wouldn't then be able to recognise who's driving for their wonderful life saving/stealth taxing speed camera's.
    Unless of course we have to have our driving licence number across the visor.
    imported_Redwing289
    [ QUOTE ]
    [/ QUOTE ]
    Instrument Lighting
    Page 87 of owners manual
    "The instrument lighting is dimmed automatically as the daylight starts to fade; it is switched off completely when the light conditions become very poor. This function is intended to remind the driver to switch on the dipped-beam headlights in good time when light conditions become poor"
    [img]/ubbthreads/images/graemlins/book.gif[/img]
    If all else fails, RTFM.
    Dec 2004
    Chester
    247
    I've just had a brain wave, I must write and tell Audi,
    I have decided I don't need their "auto headlamps"anymore ( I didn't spec these it was a demonstrator) ,
    After 32 years of driving I have at last figured out when to put the headlamps on, I know when to do this because I can't see where I am going.................
