EM TuningJMB Retrofits
Thread: Removing trim
    bobtooke's Avatar
    Apr 2006
    UK
    Removing trim
    I need to remove the interior trim panel on the side edge of the front screen to run a microphone cable from the top by the visor to behind the dash.
    How does that narrow trim section come off? Do I just pull it?
    Is it better to just tuck it behind the door rubber?
    Cheers,
    Bob
    [img]/ubbthreads/images/graemlins/confused.gif[/img]
    bobtooke's Avatar
    Apr 2006
    UK
    Re: Removing trim
    Blimey!
    Must be complicated then...
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    Re: Removing trim
    Sorry bob meant to reply to this yesterday but got side tracked! When I fitted my car kit I routed the mic cable up behind the A pillar trim without removing it.
    J.
    bobtooke's Avatar
    Apr 2006
    UK
    Re: Removing trim
    OK thanks J.
    I think I'll have a go later to see if I can get away with that. These darned Audis are made too well to pul bits off.
    BTW the first time I had to do any work on a modern Audi (my son's S2) we reworked the company slogan...
    "Vorsprung durch f**k me how do I get that off!"
