Volks AutosMonster Motorsport
    Dec 2004
    Chester
    247
    After Market RS6 Wheels
    I have joined in a few posts about aftermarket wheels mentioning my lads RS6 19's on his Golf Mk4 and how they have gone tatty over the winter. Well today we bought 5litres of Brick and Patio cleaner (seems to do the same job as expensive wheel cleaners only cheaper,5litres is about 5) and by hell does it work well! BUT on close inspection of his wheels one of them has cracked about 15mm across the spoke, looking at the wheel it shows no kerbing damage, and came off the right rear, where it probably gets the easiest ride of all 4 wheels, and having seen a number of race car wheels crack over the years it is in the area where they normally crack, all the other 3 are perfect I may add. The wheels are 5x100 8inch ET35 and are marked JWL
    Apr 2006
    Derby
    29
    Re: After Market RS6 Wheels
    best to keep away from the replicas unless they are made by a know company
    Dec 2004
    Chester
    247
    I would have thought JWL were reputable, I have seen JWL on quite a lot of wheels..
    d3fy's Avatar
    Sep 2005
    Sheffield
    1,411
    JWL is a standard as far as I'm aware and must jap car alloys will be marked JWL
    Dec 2004
    Chester
    247
    [ QUOTE ]
    [/ QUOTE ]
    Your pretty much spot on there, JWL is "Japenese wheel league" or "Japenese wheel light alloy" according to a few searches of the web, presumably the Japenese version of "TUV" still, should'nt crack should it.
