AH FabricationsChris Nott
Results 1 to 8 of 8
    Apr 2014
    Cheltenham, Gloucestershire
    19
    Audi A3 2.0TDI (BKD) Rattle and Smoke on Startup
    Hi All,
    I'm really hoping someone can help me with this problem which has caused my A3 to be off the road for three weeks now.
    Basically the problem is that when the car is started from cold there is a loud metallic rattle which appears to be coming from cylinder 1 accompanied by a puff of blue smoke and also very rough tick over for the first 10 seconds or so.
    After that the rattle calms down a little but still there like a noisy tappet coming from the left hand side of the rocker cover which does not go away.
    It has been at the garage for the last couple of weeks but they have limited experience with these engines.
    Injector 1 is showing -2.0 on flow at start up but this reduces to 0.9 when warm, injector 4 is compensating for injector 1 with positive flow. Injectors 2 & 3 are virtually at zero.
    Is it possible that injector 1 could be causing the metallic rattle if it is faulty? It is a Bosch injector which I believe are usually pretty reliable? The garage have examined the cams / followers in situ and say they can see no evidence of wear. The car has only done 68k with FSH.
    The garage seem to think that the rattle could be down to timing but I don't think that this would cause the rattle on one cylinder only?
    Has anyone experience this before on the BKD engine? The injector seals on injector 1 were changed but this made no difference.
    Any advice would be greatly appreciated!!
    TDI140's Avatar
    May 2011
    1,364
    Has the car been remapped ? Also get vag come scan done to see what the issue is
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Apr 2014
    19
    I don't think the car has been remapped not in the time that I have owned it.
    VAGCOM shows no faults found just lowish flow on injector 1.
    Apr 2014
    19
    SOLVED! It turns out that the timing was out by two teeth and the noise was valve against piston
    Apparently running perfect now will collect tonight!
    Sportback owner
    Apr 2007
    France
    496
    Sorry to be negative, but with the possibility of valves hitting pistons, I would immediately go for a simple compression test. Any loss of compression could indicate a bent valve stem. If OK, you have indeed been lucky. However, how come the timing was that far out? Has someone changed the timing belt? If not, I would worry about the timing belt tensioner.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    TDI140's Avatar
    May 2011
    1,364
    Wow my bmw timing chain ws out two teeth and it bent a valve had to rebuild engine
    Apr 2014
    19
    I think I was very lucky and that the valve was just touching the piston at the end of the travel.
    When I bought the car it had been accident damaged and I now have my suspicions that the cambelt may have been nipped during the collision causing a jump of two teeth. A new belt and water pump has now been fitted and the engine is running quiet so hopefully there will be no lasting damage.
    TDI140's Avatar
    May 2011
    1,364
    Very lucky
    Good on ya pal :-)
  1. audi a3 2.0tdi 140 black smoke and whistle noise
    By afzal0121 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2014, 16:04
  2. audi a3 2.0tdi 140 black smoke and whistle noise
    By afzal0121 in forum General Chat
    Last Post: 5th June 2014, 13:46
  3. audi a4 2.0TDI BRD engine thick black smoke and loss of power under load
    By kmitch93 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th May 2014, 21:24
  4. audi a4 2.0TDI BRD engine thick black smoke and loss of power under load
    By kmitch93 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd May 2014, 21:20
  5. Replies: 3
    Last Post: 3rd August 2013, 08:36
