MY09 wing mirror indicator change
Artimus
Shortback
Hertfordshire
Does anyone know if the wing mirror needs to be completely removed to replace a cracked indicator (housing is fine) or can you just remove the innards with the mirror in place?
my manual is for the 08 model which has a different housing.
Thanks.
No mate just remove the cover & disconnect the indicator connector
Reactions: Artimus
You're a Star Nigel, took about 15 minutes, and that was because the indicator was a tight fit.
Thank You.
Old
ImageUploadedByTapatalk1406379408866280
New
ImageUploadedByTapatalk1406380569419517
