Chris NottSky Insurance
Results 1 to 12 of 12
    Jan 2014
    61
    oil pressure warning ?
    Hey guys. Just a quick one. I took a roundabout hard last night and my dash flashed up oil pressure a couple of times then went off. Has anyone had this before or know what it could be ?
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    What engine?
    Also, if my oil pressure light flipped on, it would not get the chance to come on again because i'd be engine-off at the side of the road ringing the AA for a flatbed praying I didn't find engine-cheese-gratings in the oil.
    Also if it came on under hard cornering, that'd point to it being an actual pressure problem not just a faulty pressure sensor. You're lucky you didn't starve the engine under cornering force and knacker it.
    I know I wouldn't be driving it again until I knew what was up. If it's a 2.0T they are bad for gunky clogging in the pickup pipe.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Jan 2014
    61
    It's an S3 mate. Oh god am scared to drive it now.
    S3 AEX's Avatar
    Jul 2011
    222
    Don't worry they can flash up if under hard cornering, my other did it I just checked oil an was a tiny bit low so did oil change kept it at optimum level an never happened again. You certainly won't be the only one that's had this under hard cornering.
    Jan 2014
    61
    I have just checked the oil and it's just above minimum. So gonna top it up now. Could this be the cause then do u recon ? Also do the S3's use a lot of oil ? As I only topped it up about 2 month ago ?
    Cheers again guys.
    Sep 2013
    Portsmouth
    247
    Having low oil can cause the light to flick on under spirited cornering
    Jan 2014
    61
    Spot on mate that's made me feel a bit better. Topped up now ready for graft in the morning. Then take it down audi for a check over on Friday.
    Cheers for the help guys.
    S3 AEX's Avatar
    Jul 2011
    222
    Yep that will have been your cause, some tfsi engines use a lot some don't. My other S3 used a lot so did my mates 1.8 tfsi, the one I've got now not so much.
    wuta3's Avatar
    Jul 2012
    1,075
    I've ran my oil too low (shame) on occasion but never had a pressure warning, even under hard cornering.
    Yes TFSI engines can drink oil, mine can do 1L every 1K miles or less.
    Jan 2014
    61
    Hmm need to keep an eye out on my oil more often from now on then. Just hope everything is ok. I read a post about an oil return pipe or something like that. Ppl say it gets full of gunk will I be able to check this myself or will it be best to take it to a garage ?
    wuta3's Avatar
    Jul 2012
    1,075
    Quote Originally Posted by AAR4N View Post
    Yea the pickup can become blocked, happened to me and I heard a few horror stories about it. To replace it's sump off, £20-ish pipe that has a round thing and a mesh on it. Easy to spot.
    Jan 2014
    61
    OK mate cheers. Al have a look in the morning. Cheers for all your help bud. Much appreciated.
  1. Oil pressure warning light
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2005, 02:31
  2. Oil pressure warning light???????????
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2005, 16:22
  3. Oil Pressure warning light
    By imported_scooters in forum Classic Audi Forum
    Last Post: 30th May 2005, 21:32
  4. Allroad oil pressure warning on
    By in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th December 2004, 21:02
  5. 1.8T oil pressure warning - advice sought
    By imported_CurryMilkShake in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2004, 01:28
