JMB RetrofitsChris Nott
    TDI140's Avatar
    May 2011
    1,364
    Top mount loose how too tighten whilst on the car ? Need allen key and spanner ??????
    Any clues or tips how to do this ? Knocking noise is so annoying
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    swan neck spanner and a allen key might do it.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    688
    Easiest option is to use an air gun.
    Other than that yeah swan neck spanner and Allen key.
    IBIS WHITE S3
    Revo stage 2+ and loving it
    May 2014
    10
    Got to be careful using an airgun while doing up that nut, can strip the threads on the strut quite easily.
    I only know because i did it on some brand new Koni shocks!
    TDI140's Avatar
    May 2011
    1,364
    Got to buy some swan neck spanner then one side just tightened with a wratchet spanner no allen key was needed weird
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Or.... Set of large mole grips with lots of paper (or possibly a flannel) in the jaws so when you tighten it up it doesn't mark the piston rod. Then use a normal socket on the top whilst holding the grips. Did mine like this caused no damage whatsoever & is still fine 15k miles later.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
  1. Replies: 16
    Last Post: 22nd November 2010, 00:53
  2. how hard / easy is it to fit jbs top mount?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2008, 09:30
  3. Whilst Idle - the car jerks/revs rise a little
    By GibletsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2007, 19:12
  4. can too much coolant damage the car/engine?
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2007, 17:32
  5. How do I tell if the car has a K03 or Ko3 Sport
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2005, 11:48
