JMB RetrofitsVolks Autos
Thread: scanned
    Jan 2012
    powys
    59
    scanned
    iam have my car scanned on fri via vdcs , becouse when i start the car from cold it sounds like its missing , when warm you cant here it so much , i think its either my cam chain or a coil pack failed .
    while there scanning my car what should i ask them to cheak . its had the recall on the coils 5 years ago.
    A3 3.2 v6 dsg 2005
    Jan 2012
    powys
    59
    had my car scanned on fri . wanted to use the vdcs but he used the Audi scanner because these are Audi specialists , sounded expensive at £11500 .
    he scanned my car of all ecus found no fault and read all sensors . he said there was no slack in the chain , but what he did notice was cylinder 4 was had a higher reading than the rest but he said this is nothing to worry about 1,2,3,5,6 were reading 0.22-0.28 , cylinder 4 was 0.45 he said this is so slight .
    when i got to his garage the car warm so hardly missing at all , but its only when i start from cold its very bad .
    he said it wont be a coil pack because it more violent of a shake , hes known these engines break engine mounts from people driving with bad coils .
    i cant under stand why its more from cold start , if it was coil would it be the same all the time .
    oh and there is a CAN update for my car but dont think i need this .
    thanks Ray
    Jan 2012
    powys
    59
    any one !
    Jan 2012
    powys
    59
    its ok while driving you cant realy feel it . not sure if its down on power dont usaly drive it quick.
    could it possibly be the battery low on power cousing lumpy tick over.
  1. Free delivery for life scan computers
    By AndyS3 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 12th November 2006, 12:53
  2. vag-com abs scan results, couple of questions.....
    By darby7 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th July 2005, 11:47
  3. vag.com not scanning
    By scrappydoo in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2005, 20:20
  4. vag-com scan
    By NOGAROS3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2005, 09:23
