Am having the same issue with a car i just bought. wondering if this is the same car. I scanned it and the following codes came up. I reckon the cluster is defective and may need to be repaired or replaced.
Friday,12,December,2014,00:58:21:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8P74A166838 License Plate:
Mileage: 247560km-153826mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P74A166838 Mileage: 247560km/153826miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0D3FN10FK
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 275D1D179618CF26F59-8072
1 Fault Found:
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal - Intermittent
Readiness: 0 1 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
VCID: 3A7BD46375AA42CE9A7-806F
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 045821 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
VCID: 2D51EF3FB4E4E5760F5-8078
2 Faults Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000723737
Coding: 01884F00A2141000000000000000000000
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
5 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
00926 - Terminal 30
011 - Open Circuit - Intermittent
02071 - Local Databus
004 - No Signal/Communication - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
VCID: 4385A98702600306C91-8016
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 306FF64BA3D6889E243-8065
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2243DD09006229
Coding: 0004403
Shop #: WSC 00999 444 64523
VCID: 3C77D27B7F9E7CFE88B-8069
1 Fault Found:
00003 - Control Module
014 - Defective
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001043190148
Coding: 3D0F0B42070101
VCID: 285F1E2B9B06C05EFC3-807D
1 Fault Found:
01304 - Radio
Address 25: Immobilizer
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 3979CB6F70AC49D693D-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.10 1301
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 00046 412 819200
VCID: F9F98B6FB02C09D653D-80AC
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
2 Faults Found:
01134 - Alarm Horn (H12)
000 - -
01299 - Diagnostic Interface for Data Bus (J533)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001116105
VCID: F0EFB64BE356489EE43-80A5
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C57E23B8FFEEC7E18B-8079
2 Faults Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
01320 - Control Module for Climatronic (J255)
