Volks AutosSky Insurance
    Nov 2013
    Suffolk
    46
    Add cnahamilton on Facebook
    Rear wiper washer jet doesn't work :(
    My washer jet does not work. I have taken off the boot trim and had a look in there for any gremlins and there was nothing wrong. water pipes fine, all electric connections were fine. Pump makes a noise when activated but nothing happens
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    485
    On the wipe itself you should be able to see the x2 nozzles which fires the jets.
    Remove these by pulling them and clean them out - i would guess these are blocked if you can deffinetly hear the pump running,
    Jonny
    Oct 2012
    70
    Does water come out of the pipe at the back when you try the pump with it disconnected from the wiper motor? If not then maybe there's a leak /pipe has come off in the front somewhere on its way from the reservoir to the back of the car? I had that happen to my 8l where it wouldn't send any water to the back until you'd held the pump on for a good while because it was leaking at a connection near the bulkhead.
    Nov 2013
    Suffolk
    46
    I didn't think to do that while I had it apart. Th pump definitely runs. I have also checked if any water leaks from anywhere when I get the pump going. Nothing leaks from the tailgate and I can't see any leaks from the front. Ill pull ff the jets and try that.
    27,073
    As stated above, disconnect the pipe & test again, also as above its probably just blocked jets.
    Mike X's Avatar
    Nov 2011
    East Yorkshire
    60
    Add Mike X on Facebook
    I had the same problem , I blasted the nozzles with a power washer , then ran the wash / wipe , then blasted again , I repeated this a few times until they cleared , a fine sewing needle helps too .
  1. Rear Wiper Washer Trouble!
    By Adam-f in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2011, 16:48
  2. Rear wiper / washer / alarm problems.
    By a3a3a3 in forum The Welcome Section
    Last Post: 11th March 2011, 17:55
  3. Rear wiper washer not working? 2004 8p
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2011, 16:40
  4. rear wiper on b6 avant,, not working!
    By Leaky Lloyd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2010, 19:45
  5. Avant - Rear Wiper / Washer
    By sc00byd00byd00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th June 2009, 10:00
