right ive got a 04 3.2 dsg Quattro 59kgot it April , always had this problem but has got worse over time when turning right even just the slightest amount it starts to vibrate on what seems like the (passenger) left hand side wheel ,the more you turn right the worse it gets . straight line or left its mint .
its on new coilovers ,new topmounts and droplinks
there is no play side to side or top to bottom of the wheel
ive changed wheels front to back
I had the car up and running with no car weight or outwards force from cornering on the wheels the car does not vibrate turning right
drivers side drive shaft has about 5mm play hub to tran
passenger side drive shaft has no movement what so ever on it so im thinking this could be part of the problem and maybe the gearbox mount might be going.
Just wanted to get a second opinion and see if anyone else has had this problem
