EM TuningMonster Motorsport
Results 1 to 7 of 7
Thread: plastic welding
    May 2013
    32
    plastic welding
    Hi all, does anyone have any experience of plastic welding, my wife got my sline stuck on a curb and pulled the left hand side of the bumper off. It has ripped off the tension part that the bolt goes into. Tried the super araldiet and some quick set putty to build it up with no joy as soon as it is under tension it comes off. I have plastic welded a bike fairing up in the past but that was a crack to a stuck on part. Am i wasting my time or should i buy another bumper. Cheers
    27,096
    Pics would help the advice given mate, araldite is useless, topfix is the kiddy but depends on the job at hand, hence pic request
    May 2013
    32
    OK here it is. i still have the ripped part just about hanging on but you get the idea of where it has come away from.
    27,096
    Oh that's a bugger to repair, plastic welding may work, but painting would be required I suspect with the heat in the area, you could try topfix, £25 a pack & nozzles are £1 each one use only its a great plastic repair I use for multiple applications, goes of like a weld joint, but rough up the area well so it bonds well.
    May 2013
    32
    Ok. Thank you I am willing to try. Where can I get topfix as nothing came up on a search. Thanks again
    27,096
    Innotec direct usually.
    May 2013
    32
    ok thanks did not know thats who made it, will have a look. thanks
  1. plastic welding S3 bumper or getting a new one
    By sportstractor in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2010, 18:10
  2. Plastic welding.
    By Soupie69uk in forum General Chat
    Last Post: 3rd May 2006, 08:41
  3. Downpipe, worth getting new flex joint welded in?
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2005, 09:21
  4. Plastic window over VIN plate cracked and split
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2004, 08:51
  5. Creaky plastic
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2003, 15:21
