Chris NottBadger5
Results 1 to 13 of 13
    Apr 2014
    Stoke On Trent
    32
    RNS-E Not Turning Off???
    I've just bought the Sat Nav Plus RNS-E which is great. However when I pull the key out the display turns off but I can still hear the fan going really faintly and when I turn it on it appears immediately it's not booting up like it should?
    This happened the other day with my BNS 5.0 sat nav so I'm beginning the think there is an issue with the car not the unit?
    Anybody got any idea what it might be? I don't want to wake up to a drained battery again...
    Jan 2012
    1,837
    What you're experiencing is normal.
    It stays in like a standby mode for a period of time (fan will go off if you leave it long enough) to allow immediate use. After 1/2 hrs it'll go back to the startup screen.
    Apr 2014
    Stoke On Trent
    32
    Thanks for the reply!
    I'll try it in an hour to make sure
    Jan 2012
    1,837
    Well as soon as you open the door the fan will come back on.
    Apr 2014
    Stoke On Trent
    32
    Yeah but it should show the boot up screen
    Jan 2012
    1,837
    Yup.
    Apr 2014
    Stoke On Trent
    32
    That's all I'm bothered about. It's just my BNS was playing up earlier this week, I couldn't turn that off, I could hear interference coming out the speakers when the key was out and it drained my battery. Don't want the same happening
    Jan 2012
    1,837
    Has the unit been coded correctly with vcds? Any underlying problems with the car ie electrical problems on vcds?
    Apr 2014
    Stoke On Trent
    32
    No not been coded in yet
    Jan 2012
    1,837
    Shouldn't make a difference really but get it done ASAP. Also clear and rescan for any faults, you'll probably find a ZF antenna error but this can be ignored.
    Leave the car 90-120 mins just to make sure.
    Apr 2014
    Stoke On Trent
    32
    Right ok. What does coding it actually do? Everything is working on it? I'd take it Audi to be scanned but I imagine it'll cost a fortune
    Jan 2012
    1,837
    Take it to a Audi specialist or look at the vcds user map in the vcds section.
    Coding means that the car knows exactly what's been fitted and exactly what that part is currently doing.
    Apr 2014
    Stoke On Trent
    32
    Right ok. I'll take it to an Audi specialist then. Cheers pal
  1. Fans not turning off 3l tdi
    By JD09 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th January 2013, 18:37
  2. Stereo help does not turn off with key!
    By JA50N in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2012, 19:45
  3. lights not turning off!!! :@
    By audi-tk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2011, 23:25
  4. Service Light will not turn off
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2010, 14:46
  5. Cooling fans,not turning off
    By evocos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2010, 15:29
