JMB RetrofitsVolks Autos
Thread: Fuel Pump Prime
    Aug 2012
    13
    Fuel Pump Prime
    Hello,
    Can someone with a 2.0 TDi 170 confirm whether they hear the pump prime when opening the drivers door? Or should it only do it when ignition is on?
    Phil-1's Avatar
    Sep 2013
    Harrogate
    1,106
    I have never heard my pump when opening the door. I struggle to hear it in the car when I switch it on.
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagust.co.uk
    E-Mail:info@philseagust.co.uk
    Oct 2009
    25
    hi mine is the same it only primes when you switch it on. The issue i have is if i don't use the car for a few days it will not start straight away, it takes a coulple of cranks to fire up.
    So what i do now is to prime it a few times and it fires on the first crank.
    Aug 2012
    13
    Quote Originally Posted by j4yvw View Post
    Thats the very same issue I have. Trying to get to the bottom of it as it's getting worse to start from the first cold start of the day. As in takes around 8 goes before it starts.
    Noticed its more when the car has half a tank or less of derv left.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    I have the same problem: Audi A3 TDI Does not start when fuel less than half a tank
    I've recently got a used in-tank pump from a friend, for testing and the starting problem has gone.
    I'm going to buy a new pump.
    The problem is that there is a one-way valve on the circuit that should prevent the fuel to drain back in the tank. This valve is failing and can't keep the system pressurised.
    A lot of details here: 2005 BEW PD lift pump operation and internals - TDIClub Forums
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
  1. Extending priming on fuel pump.
    By Rosso TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2013, 11:13
  2. Noisey fuel pump priming
    By marmite in forum RS6 Forum
    Last Post: 13th January 2007, 19:12
  3. best place to buy a late coupe fuel pump
    By lazzaman in forum Classic Audi Forum
    Last Post: 25th November 2006, 21:48
  4. Fuel pump problems
    By nunzio42 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 12:09
  5. Fuel Pump Noise
    By europabluea6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th September 2003, 18:15
