AH FabricationsJMB Retrofits
    Gaz-M's Avatar
    Jun 2014
    98
    "Right Parking Light" on dash- all lights ok!!?
    Today i got a bulb failure warning for right parking light. All lights working but replaced anyway and still showing fault. Cleaned rear with contact oil too.
    Whats the parking light, surely same buld as the sidelight?
    Its so annoying beeping and showing failure light!!
    pluves1's Avatar
    Dec 2008
    354
    I thought parking light was when you had indicator stalk up or down which then set the parking lights on. So depending on which way the stalk is pushed this puts on both the front side light but, more importantly the rear light - did you check the rear as well?
    Now
    MY10 BMW 335d Touring (Sapphire Black)
    MY10 S3 Sportback (Sprint Blue)
    Previously
    06 BMW 330d M Sport Touring Le Mans Blue with Black leather, Phone Prep
    Gaz-M's Avatar
    Jun 2014
    98
    Yeh it does, it puts sidelights on. Both front and rear are fine and i replaced them anyway- still the same!! Frustrating. Stupid warning system!
    Gaz-M's Avatar
    Jun 2014
    98
    I think its the DRL bulb, qre they just standard single filament 382 bulbs?
  1. ESP warning on start up and esp light on dash all the time!
    By Ripitup in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2012, 16:56
  2. WARNING/FAULT LIGHT ON DASH ALL THE TIME...
    By stacey bear in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2010, 13:36
  3. ABS and ESP lights on the dash all the time
    By vrbob in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 19:09
  4. Dash board light problems??
    By Vorshprungdork in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th November 2005, 19:12
  5. blue light conversion on dash? any advise?
    By darby7 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2005, 23:01
