Monster MotorsportVolks Autos
    Jun 2014
    coolant temp sensor, radiator outlet signal too low
    Hi guys basically getting this fault on my bkd 2.0tdi engine and it's bugging me any ideas?? I've changed both sensors and still coming on??? Basically soon as key is in the ignition the fans come on.
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    631
    Something in my mind tells me the connections at the bottom of the radiator gives problems.
    It maybe worth a quick check of the wires and connectors.
    IBIS WHITE S3
    Revo stage 2+ and loving it
  1. 16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 14:59
  2. 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    By casiodan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2011, 21:25
  3. URGENT - COOLANT TEMP SENSOR
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 22:13
  4. V6 coolant temp sensor & idle speed control valve
    By JDA in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2004, 18:27
  5. Coolant Temp Sensor
    By teknobod in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd January 2004, 11:14
